Old 04-22-2008, 10:20 AM   #1 (permalink)
Stealthmode93
Stealthmode93's Avatar
Drives: Stealth
Stealthmode93 is an unknown quantity at this point
Default Need help (flex-lite fan wiring)
As the title says I need help wiring in my flex-lite fans to the stock wiring harness. I want them to run with the temp control like the stock ones did. If anyone has done this could you explain how you did it?
STEALTHMODE93
Stealthmode93 is offline   Reply With Quote
Old 04-22-2008, 10:40 AM   #2 (permalink)
Verified Asian
Sean3S's Avatar
Drives: 94 TT
Trader Rating: (36)
Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7Sean3S Level 7
Default Re: Need help (flex-lite fan wiring)
Best bet would be to get a fan controller, you can get one for pretty cheap and it uses a temp probe to turn on at a set temperature.
'94 RT/TT
13T's | PTE FMIC - PPE Pipes | 560's | Supra FP w/ 8ga Hotwire | MAF-T 1.37 & LT1 Blow-Through | E-Manage Blue w/ Boomslang Harness | HKS DLI | Stillen Downpipe | Gutted Rear Pre-cat | Borla Catback | Tial BOV | AEM FPR & Rob Beck Adapter | DejonTool Intake Pipes | PWR Radiator w/ IPS Pipes | FAL Fans | MP Motor Mounts | 99 Lash Adjusters | Clevite 77 Rod & Main Bearings | Leatherseats.com Dk. Graphite w/ Red Center Seats | Sparco Flash 5 Black w/ Red Alcantara | Spec Stg. 2 Clutch & 3SX Clutch Line | 3SX Crank Pulley | Bob's SS Shifter & All Solid Bushings | NGK Coppers & MSD Wires | eK2 EGR Blockoffs | eK2 Fuel Line Loop | PST 1 Pc. CFDS | Volk LE37T | Falken FK452 | Megan Racing Coilovers | Adj. Rear Control Arms | Slotted Rotors w/ Hawk HPS Pads | GReddy Profec B | AEM UEGO WB | GReddy PWH Boost, EGT, GReddy OP, FP, Temp | Hybrid Logger | McColluch 5300K HIDs | Shaved '99 Bumper & Turns | PRM Style Hood
295.7 AWHP / 310.3 TQ @ 1 Bar - BPU @ TX04
Collecting Dust - Setrab Oil Cooler, Snow Stage 2 Meth, Brake Lines
Some Day - ABS Delete, Ducting
WTB - ek2 Harness Cover (above the fuel rails)
Sean3S is offline   Reply With Quote
Old 04-24-2008, 10:27 AM   #3 (permalink)
Stealthmode93
Drives: Stealth
Is there any way that I can just wire them in tho the stock radiator fan and ac fan harnesses without buying any extra controllers? That way I can still use the stock sensors in the bottom of the radiator.
Old 04-29-2008, 07:34 AM   #4 (permalink)
Mr. Self Destruct
gambino's Avatar
gambino is an unknown quantity at this point
This should work:
Wiring Flex-a-lite fans how to?
For the condenser fan I used the blue and blue/black for power.
Jacob
97 VR-4 DR-1000s, AEM EMS
[ 2003 Ninja 500R ] [ 93 VR-4 - Sold ] [ 99 GS-T - Sold ]
If an injury has to be done to a man it should be so severe that his vengeance need not be feared. - Niccolo Machiavelli
gambino is offline   Reply With Quote
Old 05-24-2008, 09:06 PM   #5 (permalink)
SPYDERTT's Avatar
Drives: 95 Spyder VR4
SPYDERTT is an unknown quantity at this point
Just got mine done. Looks like this. Cut the wires off my old fans and soldered them to my new fans , also using the factory resistor. It's beer break , then we'll see if they fit.
SPYDERTT is offline   Reply With Quote
Old 06-03-2008, 10:17 AM   #6 (permalink)
Stealthmode93
Drives: Stealth
Thanks, guys I'll try that tonight.
