Old 05-25-2009, 01:26 PM   #141 (permalink)
Born In Italy
italiano3kgt's Avatar
Drives: lika bat out a hell
italiano3kgt is an unknown quantity at this point
Default Re: My Poor Car!!!!!!!!!!!
im going to paint the engine bay black. should be starting that tomorow morning.ill take some before and after pictures.
hunny, PLEASE all i hear is "blah", ok? in one ear and out the other....
italiano3kgt is offline   Reply With Quote
Old 06-05-2009, 01:42 PM   #142 (permalink)
Born In Italy
ok so i got pretty damn far on this from where i was. but now i ran into another problem and im really pissed off. you can see why in the pictures.
at first everything is all good. music drinkin a beer with some friends.
and then.....
nnnnnnooooooooo....
so now i have no clue on what to do. i would like to weld it but im not sure if its to far gone to be welded. what do you guys think??
Old 07-15-2009, 09:39 PM   #143 (permalink)
Born In Italy
trans is off and ready to be sent to 3sx. they are going to put a new mid housing on it and rebuilt it. next step is finding the right motor mounts i need.
Old 10-24-2009, 02:41 PM   #144 (permalink)
VA 3S
Tool Man's Avatar
Drives: 94 3000GT FWD TT
Trader Rating: (38)
Tool Man Level 1Tool Man Level 1
So, where are you on this? Any new pics?
Tool Man is offline   Reply With Quote
Old 11-01-2009, 02:39 PM   #145 (permalink)
Born In Italy
Arrow Re: My Poor Car!!!!!!!!!!!
alright guys. i feel like im digging up an old ass thread. but here is the progress.
the 95 vr-4
dents and body work fixed.
interior swaped over from other car and some other stuff.
and she is in....
Old 11-01-2009, 03:08 PM   #146 (permalink)
VA 3S
Tool Man's Avatar
Trader Rating: (38)
Tomorrow looks like crap, I'll swing up Tuesday morning. PM me your address.
Old 11-01-2009, 05:56 PM   #147 (permalink)
From KDM to JDM
Keyan's Avatar
Drives: Red 93 VR4
Keyan is an unknown quantity at this point
speedo cover has wrong top speed...
Keyan: superhero halloween party, huh?
1320VR4: exactly
1320VR4: maybe i'll wear a cape and be 3s boy
1320VR4: and you can be turbo lag! my arch rival!
Keyan: yes yes yes
Keyan: i will just be a caped, masked gray figure, with a boost gauge that reads -10 and I'll get some little kid to be my cohort, Spun Bearing Boy.
1320VR4: LOLOL!
Keyan: and you have to wear a fat suit.
Keyan is online now   Reply With Quote
Old 11-01-2009, 06:02 PM   #148 (permalink)
Born In Italy
yes i know its out of a base but i had to go with that cluster because the trans is a cable driven speedo insted of the elctronic speedo.
Old 11-01-2009, 07:28 PM   #149 (permalink)
Born In Italy
i think it should be up in time for me to run for the january ROTM. i have a suprise on the color, i think the color im going with will a color make this car stand out so well and the wheels that im getting are very eye catching but not to flashy. i think i like the wingless look alot better. so im just going to lower the hell out of it and keep it wingless.
Old 11-01-2009, 10:13 PM   #150 (permalink)
nkl420's Avatar
Drives: to fast
nkl420 is an unknown quantity at this point
Originally Posted by italiano3kgt View Post
ok so the shell im getting has a cracked windshield. i hava a perfect one one my parts car. i was wondering how hard to remove and replace the windshield is?? also does any one know of a write up on how to do windshield replacement.? what parts will i need?
thanks in advance.
seperate window from urethane
remove windshild from car
remove old urethane
clean and dry the area
using a rethane gun, put one solid stripe of urethane around the opening (use to much urethane and it will go everywhere when you put the windshield on) remeber, its going to spread out both ways, make sure you put the urethane in the middle, not off to the side.
carefully place the windshild on the urethane, then ajust it accordingly.
try to put it on as good as you can, so you dont have to move it to much while its on.
tool you will need:
a windshield remover helps for the first step, but ive seen it done, easily, with a putty knife.. make sure its long, skinny, and has a rounded tip. the metal should also be thin so you can get it between the car and the windshield easily.
a urethane gun and urethane
suction cups help for R&I but again, not nessisary
lots of rags and alcohol ( i reccomend adhesive remover)
make sure you do it in a warm area and dont drive it/expose it to cold for 2 or so hours after the install
Edit: make sure you wear rubber gloves, lots and lotsof rubber gloves no fingerprints!
and try not to get uurethane on the windshild (well try not to get it on anything, esp you interior)
nkl420 is offline   Reply With Quote
