#1 (permalink) |
Gearhead
I couldn't find a valve spring compressor that would work without taking the heads off. I bought two different ones that didn't work because there is no room around the springs for the little arms that are supposed to hook onto the lower coils. Supposedly there is a Mitsubishi tool that will work but it's $200 if you can find it (I could not). So, I made my own from commonly available parts I bought from Home Depot for less than $15.
The photo below is the valve spring compressor in action. The posts following will explain how to make it.
1992 Stealth Twin Turbo - 352 awhp, 378 ft-lb awtq @ 16 psi
15G's, DSM sidemount intercoolers with electric fans, 680 cc PTE's, Supra fuel pump, Greddy e-manage, Blitz SBC-iD/PWM-iD, lots more ![]() |
#2 (permalink) |
Gearhead
The first piece is made from a 3/4" pipe, black iron or galvanized. Cut off a piece 3 1/2" long. You don't want threads on the bottom surface that contacts the valve spring retainer. Threads on the other end don't matter. Cut out the window in the side using an angle grinder with cut-off wheel, a Dremel, or a hacksaw if you're a masochist. I used an angle grinder for the straight cut about 1/4" from the bottom and the angle cut at the top of the window, and a Dremel with a little abrasive cut-off wheel to make the cuts parallel with the pipe. Grind or wire wheel all the cut edges smooth. I tried covering the bottom surface with electrical tape so it wouldn't scratch the retainers, but it doesn't stay in place very long. None of my new retainers got scratched anyway (they're titanium). The finished piece looks like the picture.
#3 (permalink) |
Gearhead
Next, make the handle. I used a 1 1/2" x 1/2" x 1/8" channel. You could also use flat bar stock, but it would probably need to be 1/4" thick. Don't use a tube section for reasons which will become obvious. Cut a piece about 13 or 14 inches long and grind the cut edge smooth. Drill a 3/8" hole about 1/2" from one end and another 3/8" hole about 1 1/2" in from the first one.
The hook is a 5/16" x 6" screw eye with about 1/4 of the eye cut off. There are also screw hooks you can buy, but usually they have an elongated hook that will get in the way and be difficult to use. The screw eye with a section cut out works better. You also need one or two 5/16" washers and a 5/16" nut; also a 1/4" x 1" hex head bolt, about four 1/4" washers and a 1/4" nut. For initial setup, put the hook through the hole closest to the end of the bar, and put on the washer and nut. Run the nut down until about 1" of the threaded end of the hook sticks out. With the hook hanging down, put the 1/4" bolt with three washers up through the other hole, then put the other washer and the nut on and tighten the nut finger tight. The assembly looks like this. |
#5 (permalink) |
Gearhead
Step 1: Maneuver the hook under the crossbar cast into the head, approximately under where the camshaft would be (I think this is an oil passage for the lash adjusters?)
Note: In the picture, the camshafts are removed. I haven't tried this without removing the camshafts so I don't know if it is possible. You could probably do it with a little bit larger hook. |
#7 (permalink) |
Gearhead
Step 3: Make sure the pipe is centered over the spring retainer, and adjust the nut on the hook to take up any slack, then press down on the handle to compress the valve. Hold it with one hand and use your other hand to remove or insert the keepers, with needlenose pliers, hemostat or whatever. By twisting and manipulating the handle, you can control the position of the retainer with respect to the valve stem to facilitate getting the keepers in and out.
#9 (permalink) |
Gearhead
Now instead of pushing down on the handle, you have to pull up on it. It's a little harder but it still works. If you have a helper this would be a piece of cake, but I did all 24 valves by myself using this tool.
You could wrap some duct tape around the end to make a sort of handle, that would be more comfortable to use; I didn't bother. I'd estimate it takes about a 20 lb. push or pull on the handle to compress stock springs. |
