Old 05-15-2008, 06:07 AM   #11 (permalink)
reallyxxxxxxloud's Avatar
Drives: LS400/GTO vr4
reallyxxxxxxloud is an unknown quantity at this point
Default Re: Keyless Trunk Release
If your key says trunk - using a test light or mulimeter check for a positive or negitive pulse (when pushing the button) from the output you mentioned. If there is you need a trunk popper and a relay as it will be a low current output.
Hope this helps...
"Video games don't affect kids, I mean if Pacman affected us as kids, we'd all be running around a darkened room, munching pills and listening to repetitive music."
PIONEER-ODR RS-K1/C-100/C-200/RS-P50 X2/RS-P1/RS-M1
DIAMOND-AUDIO HEX 8" X2/HEX SILK DOME TWEETERS X4/D7-401 AMP X2/D7-402 X1/D7-152 AMP X1/D7-104 AMP X1 ETON 4-300/25HEX 4" X4 AUDIO-CONTROL EPIC-160
ECLPISE 10" TITANIUM (SUBSONICS) X2 SW9102
PHOENIX-GOLD 12" CYCLONES (INFRASONICS) X2 DC SERVOS http://www.phoenixgold.com/webfaq/cyclone.htm
FUSION 7 COLOUR L.E.D KITS X4 2 MODIFIED. Intergrated lighting through out install.
1994-MITSUBISHI-GTO-TWIN-TURBO-4WD-4WS-FULLY OPTIONED-SERIOUSLY being MODIFIED
reallyxxxxxxloud is offline   Reply With Quote
