supra guys are 'plagued' by too high of an oil pressure at upper rpms, it basically blows your front main seal out. my buddy's getting tired of replacing them, we're gonna try and see how we can lower the pressure
02 TI silver/black 6spd 90k on the clock
KW V3's, Eibach 2way sway bars, Headers, AEM FIC, VMR V715's Michelin PS2's 295/35/19 rear 245/40/19 front. Boost inc.
Re: How to shim your oil pump relieve valve for higher oil pressure
yeah thats what I would be worried about "playing around" with shims, adding shims is doing the opposite of what you want to do.
for the 3s...
someone correct me if im thinking wrong here...
assuming you follow the manual and check your "spring" tension and thats right on.
that spring tension is there to basically "limit" upper rpms from causing your oil pressure to blow out of everything..
its functioniong like a bov crank it down and youll get higher pressure at higher rpms...
whats 3 lbs at 2000 rpm and makes your stock gauge look nice and tidy, might be 20 lbs at 6000 rpm... thats bad...
well after doing this and later tearing my engine apart, i can assure you that i did not leak oil out of one single seal with my 2 washers. food for thought
Does anyone have any oil pressure numbers before and after shimming?
I'm going to have to take my oil pan off AGAIN because the damn black silicone didn't hold. Switching to red. I'm probably going to try this shim out. My oil pump only has about 5,000 miles on it, but it was installed almost two years ago. No telling when it was actually made.
My current oil pressure is a little low for my comfort:
This is definitly something that should not be done blindly. Too high oil pressure, especially going to happen in upper RPMs, can and will be as bad or worse than low oil pressure.
I would replace pump if it is tired, check spring to ensure it is in spec.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-770AWHP 747AWTQ 30psi E100 Daily Driver 10.57@136mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
i have seen no increase in idle pressure,and no one else will either. it would only make max pressure higher. you could weld the valve shut and it wont increase idle pressure. it really wont increase hot high rpm pressure much either unless you really shim the crap out of it. id say the valve is mainly useful in cold starts,like when you take off when cold and pressure is really high due to thick oil. when everything is hot, i doubt you are maxing the pump out to the point of opening the valve
for motor or tranny work in my area email me, bottledgt@yahoo.com
