Old 11-25-2004, 12:19 AM   #21 (permalink)
Audiophobe is an unknown quantity at this point
Default Re: How much to replace an ECU??
Originally Posted by Jscopus
The parts are actually under a dollar to replace all the capacitors. With shipping/handling about $6. Need a bit of electronics skill though.
Jeff
From what I understand from another thread and the av-pro site, it's not only a matter of changing the capacitors. The board has to be cleaned and the circuitry has to be checked and fixed if necessary.
93 VR4: 2006 Engine Rebuild/Port and Polished Heads, '99 Lifters, DR 500's, CFDS, TC Bracket, Custom Catback/DP w/precat elims, Unichip, EBC, 680cc injectors w/Denso/AEM fuel reg/Hotwired, H&R springs(-1")-new struts, SPEC 3/PLUS clutch w/Fidenza Flywheel(new), MAFT, Front/Rear strut bars, polished plenium and chrome engine dress, 18" chromies. Newer TC (recall but never had problem!) Rebuilt tranny(Kormex) 60k tune with all new parts(redone during rebuild). New starter. FOR SALE!
93 SL:
DP/ 3sX Lightened pulley, K&N intake w/ SuperMac Cold wall. SS Grey!(Died 2/07 Gone but not forgotten)
Audiophobe is offline   Reply With Quote
Old 11-25-2004, 12:50 AM   #22 (permalink)
Welcome to the Jungle
YellowES's Avatar
Drives: 1991 Stealth Base
YellowES Level 1YellowES Level 1
I'd like to know what makes you think your ECU is bad in a 1998 VR4.
2000 Toyota Celica - Burns oil like crazy...
2009 Dodge Caliber SXT
Waiting to finish my bachelors degree in 2012 before I get back into the car enthusiast game...
YellowES is offline   Reply With Quote
Old 11-25-2004, 01:32 AM   #23 (permalink)
Jscopus is an unknown quantity at this point
I just pulled mine out today and one of the capacitors has a slight brown goo at the base. Yes there is more than simply replacing the capacitors. You can clean the board with acetone. My board is a 92 and looks pristine except for this one spot. I think for a couple bucks I will try to clean it and replace the capacitors. I am pretty comfortable with electronics, and do not believe I will destroy anything. Worst case I send it for a rebuild and had a $6 crack at fixing it myself.
Jeff
Jscopus is offline   Reply With Quote
