#11 (permalink) |
vvme.com doesnt work..did you type it right?
and with 10000K, the view ahead of you isnt going to appear as bright as you would like/need...i would suggest, if its not too late, change them to 4300-6000Kmax....
#12 (permalink) | |
By the power of Grayskull
just so you know the higher the number the lower light output, or lumens i wouldnt go any higher than 6k or any lower than 4.3k(oem)
![]() ChrisEs1984 : theres alot of pushrod lovers Galganaban : i love to push my rod into your mom shawnisworking : lol shawnisworking : 0wn3d |
#13 (permalink) |
Deal with it
If they are going to be a true 10000k color you might be disappointed in the light output. If they're over color rated then you might be looking closer to 8000k which would be ok. But as others have stated a 4000k-6000k is the desirable range with the lower being brighter.
![]() It's SANDSTONE m3therf#cker - SOLD It's A 13G TT STEALTH f#cker - one of two impractical daily drivers |
#14 (permalink) |
yea, i just tried the site and its saying theres an error and wont load, but ive been tracking my order and its already in the USA so any day now....the color is what i was wanting, i like how it looks, it will give me a wider light coverage than stock
#16 (permalink) |
install is very easy, and check here for your bulb size
#20 (permalink) |
Large Member
You should just be able to mount them underneath the headlights.
IMHO, you might be sorry you chose 10000k bulbs. They might look good, but the light output will probably be pretty shitty.
2001 Ford Explorer - AWD 5.0L V8 lifted w/ 32" BFG AT K/O's
2004 Mazda6 ![]() |
