Old 06-09-2008, 07:36 PM   #31 (permalink)
Drives: '91 Stealth TT
NeoSpeed740ti is an unknown quantity at this point
Default Re: Hard start when hot
I had that problem ever since I bought the car (last summer). About a month ago I installed a AEM fpr and a supra fuel pump and the problem went away.
NeoSpeed740ti is offline   Reply With Quote
Old 06-09-2008, 07:44 PM   #32 (permalink)
daddy's Avatar
Drives: BPU 92TT
Trader Rating: (25)
daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7daddy Level 7
^ I have to note that I've also installed Walbro pump at the same time as injectors. But the stocker looked good when pulled.
daddy is online now   Reply With Quote
Old 06-10-2008, 10:04 AM   #33 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
I have an aeromotive FPR connected in a dual feed system and it did nothing to fix the problem.
I don't have the factory solenoid connected because it does not work when you are using a MAFTranslator, as the translator feeds a fixed IAT to the ECU. I have a feeling this is contributing to the problem and I plan on reconnecting the solenoid once I switch to a different system of controlling AFR.
Old 06-10-2008, 10:12 AM   #34 (permalink)
Trader Rating: (13)
I noticed my problem started after installing the PTE injectors. I sent them back for testing and I have had them tested locally 3x and they have checked out everytime.
