#22 (permalink) |
Parting out = Extinction.
Bingo….
Plus a cold car wants more fuel so this goes un-noticed. A hot car has the fuel pump holding allot of pressure causing injector to leak if dirt is holding them slightly open. If this sounds like your symptoms, it may just be the problem. I always use injector cleaner in all my cars even without the above symptoms just to keep everything clean. Again, I like Techron. You can get it at autozone. Run a few tanks with it in. Mako PS, you can always have your injectors professionally cleaned if they are really dirty.
1969 Corvette Roadster 1966 Mustang Convertible 1997 3000GT Coming soon, 1996 Viper-GTS ![]() View Pictures @ http://www.drivehq.com/folder/p2483017.aspx (Use the Slideshow feature) Last edited by mako : 08-13-2007 at 07:01 PM. |
#25 (permalink) |
I had a very similar problem, started fine when cold, hard or very hard to start when warm, and sometimes idle would be way off. It turned out to be the water temperature sensor was wacky giving the ECU bad info. Once it was replaced everything worked normally.
#28 (permalink) |
soo....cold....
replace fuel filter...that'll do it. just fixed that same problem this past weekend...took me 30 mins.
![]() Free Boost | Greddy Type-S | Cold Air Intake | MBC @ 12psi | MSD 8mm Heli-Core Wires '99 Lifters | Autometer Gauges: Boost, Water Temp, Oil Press |
#29 (permalink) |
I replaced my filter with an aftermarket aeromotive unit and it didn't help at all.
#30 (permalink) |
DoctorDex did you ever try this?? The removal not replacement.
Stealth 316 - Fuel Pressure Regulator Upgrade Stealth316.com by:Jeff Lucius "The fuel pressure control solenoid (or valve) is used by the engine control unit (ECU) only to increase fuel pressure during hot engine starts when there is a greater possibility of fuel vapor being generated in the fuel lines. When the air intake temperature exceeds 140ºF (60ºC) and the engine coolant temperature exceeds 194ºF (90ºC), the ECU uses the fuel pressure control solenoid (for up to two minutes) to allow outside air into the vacuum hoses to increase fuel pressure. In addition, the ECU increases fuel injector activation duration (richens the mixture). These two actions by the ECU are what I believe is a cause of the hot-engine hard-start condition I and many others have experienced on a hot summer day after turning the engine off for a short while. The engine acts like it is flooded for maybe a minute then runs fine. Because this is the only purpose of the fuel pressure control solenoid, I decided to remove it. I don't think there is much we can do about this part of the ECU programming short of going to stand-alone engine management. Owners that have removed the fuel pressure control solenoid, whether upgrading to an aftermarket FPR or not, have not reported problems related to this. I will update this web page if I encounter problems." Did you ever try this?? I have the same sort of problem. I have been waiting to try it, but my car has been at the shop for the last 7 weeks.
![]() Some people are alive simply because it's illegal to kill them!! If I help you out, please help make the community better and pay it forward. Last edited by mugs : 06-09-2008 at 07:40 PM. Reason: for clarification |
