Old 04-11-2007, 03:59 PM   #1 (permalink)
Davey99VR4
Davey07's Avatar
Drives: 05 GTO
Trader Rating: (16)
Davey07 is an unknown quantity at this point
Default Hard start when hot
After i drive my car for awhile, and shut it off, and then try starting it back up in five mins, it hardly starts... I have to pump the gas, and when it finally starts I have to rev it up for about a min or two then its fine. It also starts perfectly fine when its cold... wondering if anybody has had the same problem.. thanks David
99VR4 is sold i am sad
05 Pontiac LS2 GTO 1 of 8 billion,lol
Davey07 is offline   Reply With Quote
Old 04-11-2007, 06:03 PM   #2 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
Default Re: Hard start when hot
I have the same problem, although its not as severe as yours. In my case, its because the my car isn't holding full fuel pressure once the car is shut off. I haven't been able to track down the source of the pressure loss.
My problem was as bad as yours until I tore apart my entire fuel system. I checked all of my lines and I even tested my fuel pump for leak back using bucket of water and I couldn't find any leaks. Once I reinstalled everything the problem had more or less fixed itself. My car holds pressure when its off, but just not full pressure.
If I were you, I'd pull your fuel pump and make sure its not leaking around the fuel pickup - fuel pump connection. There are o-rings in there that can leak which will result in pressure loss/leak back. You can check to see if its leaking using a bucket of water.
'91 VR4 - Modlist: DR650R turbos, Snow stage 2D alky kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Dual feed fuel system with Aeromotive FPR & filter, Hotwired Supra pump, ek2mfg plenum spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP downpipe, Vac/EGR delete, Gutted precats and test pipe, Maximal solid mounts, 300m 18 spline output shaft, Centerforce Dual Friction clutch, RPS flywheel, GC coilover conversions with helper springs, Powerslot slotted rotors, Goodridge SS brake lines, Hawk pads (front), Stillen metal matrix pads (rear)
Old 04-11-2007, 11:50 PM   #3 (permalink)
Davey99VR4
Davey07's Avatar
Drives: 05 GTO
Trader Rating: (16)
I was actually thinking it had something to do with the fuel, I smelt fuel 2 of the three times it has a hard start... awesome thanks alot!!!David
Old 04-11-2007, 11:52 PM   #4 (permalink)
Davey99VR4
Davey07's Avatar
Drives: 05 GTO
Trader Rating: (16)
i really didnt think it wasmy car the one smellig but it may have been
Old 04-12-2007, 02:10 AM   #5 (permalink)
Used to Drive a Neon
Miller_Time's Avatar
Drives: 92 VR4, 98 Neon R/T
Miller_Time is an unknown quantity at this point
My issue is a little different. When the car is cold and im idling, if i press on the gas and let off quickly the car's rpms drop significantly, stalling some times. Is this common with these cars?
Originally Posted by Xyvius
She is no different then any other woman in your life and will regularly require proof of affection by means of you spending cash.. Of course on the other hand she also has great curves, loves to blow (assuming its turbo), and always "puts out", So in many ways is better then a woman of flesh.
Miller_Time is offline   Reply With Quote
Old 04-15-2007, 12:01 AM   #6 (permalink)
Davey99VR4
Davey07's Avatar
Drives: 05 GTO
Trader Rating: (16)
where can i find a complete fuel system layout*starting from the pump to the injectors???
Old 04-15-2007, 04:30 AM   #7 (permalink)
REP IS OVERATED !!
turbot4's Avatar
Drives: like miss daisy
Trader Rating: (48)
turbot4 Negative 1
i thought all these problems were isc related?
a friend of mine was having hot start issues, after he removed and cleaned his isc it was back to normal....
turbot4 is offline   Reply With Quote
Old 04-26-2007, 09:41 AM   #8 (permalink)
NJ_Stealth_ES's Avatar
Drives: Into Polls
Trader Rating: (12)
NJ_Stealth_ES is an unknown quantity at this point
my car used to do the same thing. you guys try the click-start fix? i didn't have any clicking really, but i haven't had a problem since i hot wired a relay.
NJ_Stealth_ES is offline   Reply With Quote
Old 04-26-2007, 12:30 PM   #9 (permalink)
BAWC: VP Sarcasm
CursedFish's Avatar
Drives: '93 VR-4
Trader Rating: (6)
CursedFish is an unknown quantity at this point
Mine does this sometimes as well. My fuel pump relay was fried and my car wouldn't start. I bypassed the relay and resistor as per:
http://www.stealth316.com/2-fuelpumprelaybypass.htm
Very rarely now my car will do the exact thing when warm - very low and rough idle that will die. Once I rev it past ~3k, it'll clear itself and everything will return to normal.
- '93 VR-4: RobBeck 13Ts, Emanage, etc
CursedFish is offline   Reply With Quote
Old 04-27-2007, 03:57 PM   #10 (permalink)
Drives: 94 VR4
Trader Rating: (19)
Blue94VR4 is an unknown quantity at this point
This is quite common and in most cases caused by fuel control solenoid on the firewall. When engine is hot solenoid applies atmosphere pressure (instead of vacuum) to the pressure regulator. The idea is to make car run richer first couple of minutes. To test this theory in your case connect fuel pressure regulator to plenum directly and see if it help. It's a part of vacuum reduction mod.
Good luck
94 3000GT VR4 (upgraded)
"Your 1994 Mitsubishi 3000GT VR-4 is one of 1650. There are 57 other cars that were made with both the same interior and exterior color. Exactly Identical - 8"
For sale:
1. used stock oil sender & gauges
2. used A/C belt (10K on the belt)
3. Stock front and rear sway bars.
4. 3SX dual O2 simulator
5. Used 2'' couplers/reducers/hump hoses
Blue94VR4 is online now   Reply With Quote
