Old 05-16-2005, 09:56 AM   #161 (permalink)
BUILDING CRAZY 3S's
xwire's Avatar
Drives: several VR4's
Trader Rating: (23)
xwire Level 7xwire Level 7xwire Level 7xwire Level 7xwire Level 7xwire Level 7xwire Level 7xwire Level 7xwire Level 7xwire Level 7xwire Level 7
Default Re: Engine Bay PICS (Best Thread)
Originally Posted by badass3000
xwire. very nice!!
any track times or dyno numbers or predictions? Whats your goal hp, time and psi?
not to tie this thread up more then necessary will answer this last one
so far had problems with the turbo seals when I had it on the dyno but at 18psi (where it started spewing oil) it put 433 hp at the wheels on pump gas, more tunning is scheduled later this summer when I can fly John Reed from Torque Freaks back, plans are 22 on pump, the 33 on race gas, expected numbers.... time will tell but I will say with the power it is putting down now @15psi (with the rebuilt turbo) I can only imagine how it is going to fell with some real boost and race in the tank
as far as track times I am going to wait to break something when the boost is cranked and I put it till its full power, just to damn expensive and time consuming to keep replacing shit for no good, right now just driving it and enjoying it, cars shows and the like, seems to go over well with both the import crowd and the domestic crowd as the last two shows got first in my class...
xwire is offline   Reply With Quote
Old 08-14-2005, 03:03 AM   #162 (permalink)
STANG SLAYER
DEMODEAKIN's Avatar
Drives: 1993 VR4 150 IN 4th
Trader Rating: (16)
DEMODEAKIN is an unknown quantity at this point
Bump
1993 VR4 Under Construction/ in Storage
New Mitsu Shortblock (Tallahassee Mitsu Don Keefe)
Dynamic Racing Stage 3 Heads, IPS EVO3 Kit Black Ceramic Coated/Porting, IPS TD05 FMIC, ARC2 87mm Granatelli MAS w/AEM Wideband 02, PTE 680cc,BLITZ SBC-id3,APEXI ITC, IPS 304 "Shorty" Downpipe, IPS Setrab Oil Cooler, ,T-Band Clamps,Vac Reduction,IPO Dual Feed Fuel Kit, Denso Pump Hotwired, RPS Street Maxx Clutch w/ Lightened Flywheel.
Coming Soon....AEM EMS, Aluminum Driveshaft
DEMODEAKIN is offline   Reply With Quote
Old 08-14-2005, 08:55 AM   #163 (permalink)
Ðå è$† ºƒ Ðå åÐè£ÞH
93VR4nPhilly's Avatar
Drives: Ðå ß壣z ºƒƒ î†
Trader Rating: (10)
93VR4nPhilly is an unknown quantity at this point
Originally Posted by gaines
please tell me that was a joke.....cause last time i checked you cant chrome plastic
Yeah you can...But it doesn't hold up well to heat. It's not REAL chrome, but it sure looks like it. Guess you haven't "checked" in a while
93VR4nPhilly is offline   Reply With Quote
Old 08-14-2005, 09:05 AM   #164 (permalink)
MMM RED's Avatar
Drives: 92 stealth TT
MMM RED is an unknown quantity at this point
Mine has held up just great for 2 yr's now chec my sig.
...Jay
Zoom in
Mods:
13g Turbos, HKS mbc, DNP hp conversion, K&N airfilter, ACT clutch, ATR downpipe, ATR hi-flo cat, Borla catback exhaust, Eibach prokit springs and ECS struts, Denso 195130-1020 (Supra fuel pump),eK2mfg fuel rail adapter kit,eK2mfg fuel injector wire harness cover,Aurora supermag plus ignition wires,Power Enterprise kevlar timing belt,Kormex 25 spline output shaft, eK2mfg polished "stealth" plug cover,"Chromed" timing belt covers,SS 3S short (Bobs) shifter,Pop-up headlight variable controller and 18" Panther MR175 rims
MMM RED is offline   Reply With Quote
Old 08-14-2005, 10:09 AM   #165 (permalink)
Wax on - Wax off
bslade's Avatar
Drives: 93 R/T - Beauty Blue
bslade is an unknown quantity at this point
I'll back up MMMRed on that one. His chromed Timing Belt Covers look great!
bslade is offline   Reply With Quote
Old 12-14-2005, 06:08 PM   #166 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (21)
badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5
found a new use for stock turbo's
badass3000 is offline   Reply With Quote
Old 12-14-2005, 06:41 PM   #167 (permalink)
Banned
Drives: 93 vr4
nelson bernarde is an unknown quantity at this point
ok...let's make same mess...
nelson bernarde is offline   Reply With Quote
Old 12-15-2005, 09:49 PM   #168 (permalink)
Suspended
GTO Assassin's Avatar
Drives: 1993 Mitsubishi GTO
Trader Rating: (32)
GTO Assassin Level 7GTO Assassin Level 7GTO Assassin Level 7GTO Assassin Level 7GTO Assassin Level 7GTO Assassin Level 7GTO Assassin Level 7GTO Assassin Level 7GTO Assassin Level 7GTO Assassin Level 7GTO Assassin Level 7
Dayum there are some nice engine bays kids............
GTO Assassin is online now   Reply With Quote
Old 12-21-2005, 02:58 AM   #169 (permalink)
New User
SUMO's Avatar
SUMO is an unknown quantity at this point
Some nice pictures
SUMO is offline   Reply With Quote
Old 12-22-2005, 05:17 PM   #170 (permalink)
TT's suck
TheOmniscientRT's Avatar
Drives: 94 Stealth Base
Trader Rating: (13)
TheOmniscientRT Level 4TheOmniscientRT Level 4TheOmniscientRT Level 4TheOmniscientRT Level 4TheOmniscientRT Level 4
that has to be the funniest shit ever!
there is alot diff and alot waiting so this is just to represnt the SOHC crew
TheOmniscientRT is offline   Reply With Quote
