Old 05-02-2004, 01:54 PM   #1 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (19)
badass3000 Level 2badass3000 Level 2badass3000 Level 2
Exclamation Engine Bay PICS (Best Thread)
I was searching for a thread on engine bays, but none of the pics worked b/c imagestation and others dont allow hyperlinks anymore. So, If your proud of your engine bay please post a pic. PLEASE follow these simple rules.
1. Must include 1 hyperlink (that works) per post. (use www.photobucket.com for example)
2. No Attatchments please.
3. Please turn OFF your sig
update 26sept06!!!
about three things left to do, Pollished plenum, blue couplers for MAS, twin filters w/ pipes. (Updated)
*EDIT* oops forgot my own rule #3
badass3000 is online now   Reply With Quote
Old 05-02-2004, 05:31 PM   #2 (permalink)
VA 3S
Tool Man's Avatar
Drives: 94 3000GT NA
Trader Rating: (24)
Tool Man Level 5Tool Man Level 5Tool Man Level 5Tool Man Level 5Tool Man Level 5Tool Man Level 5
Default Re: Engine Bay PICS (Best Thread)
Yeah I broke a rule, didn't turn off the sig. My Polished Plenum is due UPS on Tuesday. I'll update then.
Under the knife for a TT conversion.
Pics of my car, click me!_______ August 2006 ROTM
Tool Man is offline   Reply With Quote
Old 05-02-2004, 07:22 PM   #3 (permalink)
I can't stop modding :)
bbreese's Avatar
Drives: 92 stealth tt
bbreese is an unknown quantity at this point
rembered how to do it, here is mine
bbreese is offline   Reply With Quote
Old 05-02-2004, 08:05 PM   #4 (permalink)
Modded 360-Modena killer
mgloomis's Avatar
Drives: 94' Stealth w/twins
mgloomis is an unknown quantity at this point
Good timing for this thread to come along. I just got done installing a some engine bay stuff. Still need to polish everything clean though... I JUST finished. Still more to come, but for now I need to install my Ground Controls and get the new wheels on order.
- Mike
98' Neon R/T, Hahn Stg. 2 w/Super16G and side-mount (white/graphite w/white 15" Kosei K1s)
07' RAM Big Horn Quad Cab (white/grey w/20" chromes)
90' Sunsation Rocket 2400 (white/red/black) - 454/365HP
mgloomis is offline   Reply With Quote
Old 05-02-2004, 08:52 PM   #5 (permalink)
the car whisperer
runner4053's Avatar
Drives: 96 RT/TT
runner4053 is an unknown quantity at this point
I like your fusebox.
96 RT/TT
Currently missing an engine.
major performance mods:
DR650's, MAFT-PRO speed density, 720 cc, supra pump with hotwire, Fuellab FPR, ported heads, 1mm over intake and 1 mm over iconel exhaust valves. spec 3+ clutch, fidenza flywheel, 2 piece Al driveshaft, Supercar baffled oil pan, relocated battery, custom exhaust, reinforced bellhousing, 3sx poly motor mounts, intrax with GR-2, lots' of little things.
Waiting to get put in---> DR1000s with .48AR and stage 2 blade
runner4053 is offline   Reply With Quote
Old 05-02-2004, 11:18 PM   #6 (permalink)
LeMoN1438's Avatar
Trader Rating: (30)
LeMoN1438 is an unknown quantity at this point
dunno how to take off sigs, but heres my ugly engine. Gotta love the stock intake box
LeMoN1438 is offline   Reply With Quote
Old 05-03-2004, 12:14 PM   #7 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
Along these lines, I just painted my valve cover over the weekend and it came out pretty nice and took only a couple hours. I used aircraft stripper and a nylong detail brush. It completely stripped the old cracking paint off the cover in about 15minutes and one application. It actually looked really nice bare, but I painted it textured black and it almost looks exactly like a stock new valve cover. I was pleased because my paint jobs usually look like crap, either runny or it doesn't stick right. I used el cheapo dollar store textured paint called GripIt. I also bought wrinkle paint, but that didn't look as good on the sample metel piece I sprayed he two on to compare. polished looks good, but too much maintenance for my taste. I might do the plenum polished if I can do it myself. I would show a picture, but I dont have a hosting facility.
Sam
wraith is offline   Reply With Quote
Old 05-03-2004, 02:00 PM   #8 (permalink)
gaines is an unknown quantity at this point
see sig for mine
gaines is offline   Reply With Quote
Old 05-03-2004, 02:00 PM   #9 (permalink)
Go get bent
LUSTFUL's Avatar
Drives: Just a NA
LUSTFUL is an unknown quantity at this point
how did you get that fusebox to look so shiny.. did you go somewhere and have it chromed or what??!! that looks sweet
'93 Dodge Stealth ES: BPU and a bit more maybe
Hey bois duz dis ebay chip work make mah whip teh fasterest?
LUSTFUL is offline   Reply With Quote
Old 05-03-2004, 04:10 PM   #10 (permalink)
n' the dragon comes@niiii
morfinx's Avatar
morfinx is an unknown quantity at this point
http://www.ultimateperformanceacc.co...ss_up_kit.html
BAWC FTW
92 3000GT SL 5-Spd "Calixta" [SOLD!!]
- The Trent
morfinx is offline   Reply With Quote
