Old 09-26-2009, 06:17 PM   #1 (permalink)
Soulraver
Drives: 92 VR4 93 Stealth TT
red3000gtvr4 is an unknown quantity at this point
Default Door lock / power to door problem
I searched on here and did not find any solutions to my problem, my door locks stopped working, i tried the switches on both doors and it wont lock or unlock. Someone on here mentioned a MB543647 Relay behind the fuse box and i bought one but didn't fix anything. The windows roll up and down fine... Any suggestions?
Also a few months ago, on the drivers side only, when i hit unlock it does not work, but on the pasg side it did, i changed out the switch in the door and it did not solve the problem...
red3000gtvr4 is offline   Reply With Quote
Old 10-06-2009, 03:50 PM   #2 (permalink)
Soulraver
Default Re: Door lock / power to door problem
No one has suggestions? i tested the door lock wires coming to the drivers side door and they are good, i am really at a loss here..
Old 10-12-2009, 10:09 PM   #3 (permalink)
Soulraver
Ok so i have a complete parts car minus the engine in my driveway... its door locks work.. what should i start changing out?? anyone??
Old 10-12-2009, 10:17 PM   #4 (permalink)
RO.
RO.'s Avatar
Drives: 94 RT/TT - for sale
RO. is an unknown quantity at this point
let me know if you find a solution. the same thing happend to my car. thanks
RO. is offline   Reply With Quote
Old 10-29-2009, 05:14 PM   #5 (permalink)
Soulraver
Yeah no luck i have given up
Old 10-29-2009, 05:16 PM   #6 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (134)
Stealthee Level 2Stealthee Level 2Stealthee Level 2Stealthee Level 2Stealthee Level 2Stealthee Level 2
You need to check the harness in the door jam. There is likely a broken wire.
Old 10-29-2009, 05:16 PM   #7 (permalink)
Blue91SL's Avatar
Blue91SL Negative 1
Perhaps it has something to do with the actual wiring.
I'm not an electronics technician or anything, but bad wiring can cause shorts in your system.
'91 3000GT SL (Fiji Blue) = Some damnable engine problems (including lifter tick) and tires
'88 Ram Wagon 350 = Bent crankshaft pulley and worn suspension, BUT IT RUNS!
All my cars have problems....
Solution? BUY MORE!
HELP!: Need a 6G74 and info on the swap. Pointing me in the right direction would be awesomeness.
Blue91SL is offline   Reply With Quote
Old 11-02-2009, 12:53 AM   #8 (permalink)
Soulraver
Which wiring would i start at tho ? Would a broken wire in one of the door jams make both of the door locks not work?
Old 11-02-2009, 12:56 AM   #9 (permalink)
Damage Control
Stealthee's Avatar
Yes. Power in the drivers harness affects both sides.
Old 11-03-2009, 02:11 AM   #10 (permalink)
resident evil
wraith's Avatar
Trader Rating: (16)
wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2
Mine did that too, but if you grounded the one wire at the ETACS, both sides would lock and unlock, but only the passenger side switch would work. I installed an alarm to solve the issue
wraith is online now   Reply With Quote
