Does Barometric Pressure and Humidity affect our cars more than other cars? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 04-22-2003, 05:52 PM   #1 (permalink)
Finally back!
AustinGT's Avatar
Drives: 1999 3000GT SL
AustinGT is an unknown quantity at this point
Feedback Score: 0 reviews
Default Does Barometric Pressure and Humidity affect our cars more than other cars?
I was thinking about my problem the other day while talking to a body who has a highly modified 5.0 and he was talking about how the Humidity and Borometric Pressure (BP) affected his times. In my case I ran a 14.8 @ 96 when it was very low humidity and very high BP and about 40 degrees. Since I have been having problems it and when I made my best 15.6 @ 91 it has been very humid (90%) and the BP has been lower and the Temps have been up to 70 degrees. Will high humidity, low BP, and higher temps cause me to loose .8 on my ET and 5 MPH on my traps? Does the humidty and BP affect our cars more than other cars for some reason?
AustinGT
1999 Mitsubishi 3000GT SL
Future Upgrades:
-PMP's Intake Kit W/K&N Filter
-Borla Cat Back Exhaust System
-Custom Test pipe
-Custom Leather interior
1994 Mitsubishi 3000GT DOHC - TOTALED AS OF 1/27/04
1998 Honda Accord VTEC - Daily Driver
2002 Volkswagen Jetta 1.8T - Wife's Car
AIM - AustinGT3
1/4 Mile - 14.82@95.58 <-the last run of the '94
AustinGT is offline   Reply With Quote Quick reply to this message
Old 04-22-2003, 10:40 PM   #2 (permalink)
Drives: 03 Cobra
rtstealth is an unknown quantity at this point
Feedback Score: 1 reviews
Default
I think it affects imports more than american made cars due to the smaller more compact engines and there high compression ratios. It does however have an affect on all cars no matter what make or model.
rtstealth is offline   Reply With Quote Quick reply to this message
Old 04-23-2003, 12:20 AM   #3 (permalink)
po' petey's Avatar
po' petey is an unknown quantity at this point
Default
to any tuners & real mechanics
urban myth: advancing timing one degree for every thousand feet elevation?
po' petey is offline   Reply With Quote Quick reply to this message
Old 04-23-2003, 09:18 AM   #4 (permalink)
Senior Fanatic
Jeff Lucius's Avatar
Drives: 1992 Stealth R/T TT
Jeff Lucius is an unknown quantity at this point
Cool
The Mitsubishi ECU in our cars automatically advances timing by about 5 at higher altitude. No. Not a myth; read the service manual.
Humidity (water vapor in the air) does reduce the oxygen content but the effect, while real, is almost negligible. In fact, the cooling effect of the vapor on the intake charge probably compensates for the very slightly reduced O2 content.
Altitude always reduces the available oxygen per cubic foot of air (lower density, lower pressure). ALL engines are effected, regardless of country of origin, displacement, or compression ratio. Forced induction engines can compensate somewhat for the reduced O2 content by increasing boost.
Jeff Lucius is offline   Reply With Quote Quick reply to this message
Old 04-23-2003, 09:30 AM   #5 (permalink)
Finally back!
AustinGT's Avatar
Default
Thanks for all the info. It answered half of my question. But will the changes in Humidity, BP, and Temps make the difference that I had between my best time and what I am running now?
AustinGT
Old 04-23-2003, 10:06 AM   #6 (permalink)
TajMan's Avatar
Drives: 99 3000GT
TajMan is an unknown quantity at this point
Feedback Score: 26 reviews
Default
Does this mean that you can run slightly higher boost in high altitudes without more knock, or will it knock at the same psi in both situations?
former 3/Ss: '92 R/T[white], '94 3KGT[yellow], '92 R/T TT[black], '93 Combo-body Stealth[silver] '93 R/T TT[red]..
'93 Stealth R/T TT - parts car.. bought back
'99 3000GT base model auto - now a cheap driver, soon 4G63/AWD swap!
TajMan is offline   Reply With Quote Quick reply to this message
Old 04-23-2003, 01:42 PM   #7 (permalink)
Senior Fanatic
Cool
Without forced induction, engines tend not to knock as readily at higher altitudes because the intake charge is less dense. That is why 93 octand gas is sold in Ohio (600' asl), 91 octane gas in Denver, CO (5-6000' asl) and 87 octane gase is sold in Keystone, CO (10,000' asl).
With forced induction, you have to consider what the "boost" really is. A 10 psig (psi gauge) boost setting means that the manifold pressure is 10 psi higher than the atmospheric pressure. At sea level, 10 psi of boost means a total manifold pressure of 14.7 psi plus 10 psi or 24.7 psia (psi absolute). In Denver, CO, where normal atmospheric pressure about 12 psi, 10 psi boost means a total manifold pressure of only 22 psia.
So if all else is equal, the same engine with the same boost settings at sea level and in Colorado, the tendency to knock should be less in Colorado because the intake charge is less dense (less real pressure so charge is less dense).
In Colorado, we need 2.7 psi of boost to just be at the same intake charge density as an engine with 0 boost at sea level. And that's what I mean about a forced induction engine can compensate for the thinner air by increasing boost. Normally aspirated engines just have to live with it.
Old 04-23-2003, 04:59 PM   #8 (permalink)
TajMan's Avatar
Drives: 99 3000GT
Default
Well that seems like good news to me up here in Utah. I can run a few higher psi according to the gauge and not knock where as somone at sea level reading that much psi would be knocking.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
