Old 10-09-2004, 11:43 AM   #11 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (20)
Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4
Default Re: Details on my new oil cooler setup
If you have them in parallel it will actually be less restrictive than stock as the oil will have two paths to choose from. Stacking them like that will surely have a negative effect on the rear coolers efficiency though. If you want max effort cooling you need to give them both their own ambient air.
96 Dodge Stealth R/T TT w/59k
10.396 @ 138.94 (C16+Meth)
10.898 @ 130.00 (91+Meth)
Trevor is offline   Reply With Quote
Old 10-09-2004, 11:32 PM   #12 (permalink)
15G's are not big!!!
Drives: 95' Grand Cherokee
gofastman is an unknown quantity at this point
Originally Posted by Trevor
The oil coolers are going to Setrab STD 125 series.
http://www.setrab.se/setrab.htm
http://www.setrab.se/downloads/en_STD.pdf
If you've listened to Todd Shelton's (StealthTT) oil cooler posts I'm sure you've heard of them. Setrab (and Mocal too) produce THE best oil coolers on the face of the earth. Formula 1, CART, Nascar...most cars use Setrabs. Their design and manufacturing techniques run circles around the run-of-the-mill coolers. Problem is you pay the price for them. The coolers I got measure 7.5" high, 8.25" wide, & 2" thick. That's the most cooler I could fit where the stock IC's used to go...after all I still have FMIC piping going thru that area. I made up cardboard mockups to test fitment of the coolers and the 125's were it. They were $165 each and the four -8AN fittings were $25.
any idea how the setrab coolers compair to perma cool's coolers? this one says it provides up to a 95*f drop in oil temp, also what are the pros/cons of coolers with multiple pasages for the oil to flow (setrab) vs coolers like the one here?
gofastman is offline   Reply With Quote
Old 10-10-2004, 03:28 AM   #13 (permalink)
Z15A Tweaker
Trevor's Avatar
Trader Rating: (20)
That's a tube & fin oil cooler. It flows well with minimal pressure drop.
The stacked plate (or plate & fin) design like the Setrab cools better but flows worse. I've seen claims of a 35% efficiency increase over the tube & fin type.
I guess it depends on what you want. If you want the coolest oil go with the plate type and if you want to maintain high pressure thru the cooler you can run a tube type. Then again if you're a big nutball you can run two plate type coolers and get maxmimum cooling with minimal pressure drop.
Old 10-13-2004, 09:13 PM   #14 (permalink)
Forum Moderator
HilbillyHomeboy's Avatar
Drives: Tin Indian
Trader Rating: (39)
HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2
Damn, I'm very interested in this. I am afraid it is over my head though. I scare easy.
Jeremy
HilbillyHomeboy is offline   Reply With Quote
Old 10-15-2004, 06:52 PM   #15 (permalink)
*Insert Evil Laughter*
Eric_VR-4's Avatar
Drives: 93 VR-4
Eric_VR-4 is an unknown quantity at this point
Right on.. I'd have already done this myself if I had a center mount intercooler. cooling the oil is a very good thing... I plan to get a larger and better oil cooler at some point... for now front mounting the stock one helped a tick or two on the stock oil pressure gauge
Eric_VR-4 is offline   Reply With Quote
Old 10-17-2004, 11:49 AM   #16 (permalink)
Photography Guru
Mobo's Avatar
Drives: Money sucking VR4
Trader Rating: (40)
Mobo is an unknown quantity at this point
Keep us updated on how well this works out. I've been talking to another board member about this for 1.5 years now. I'm just not home to mess with the car. Guess I'll just let you test it out first
Keith Upton
Perfomance Imagery
Fine Art Automotive Photography
719-661-0161
services@performanceimagery.com
Mobo is offline   Reply With Quote
Old 11-20-2004, 01:23 AM   #17 (permalink)
165 mph and counting...
UTRacerX9's Avatar
Drives: like Jason Bourne
Trader Rating: (8)
UTRacerX9 Level 3UTRacerX9 Level 3UTRacerX9 Level 3UTRacerX9 Level 3UTRacerX9 Level 3UTRacerX9 Level 3UTRacerX9 Level 3
Very interesting... I looked at going with an aftermarket Setrab when I did the oil cooler/ DSM intercooler install. Thanks for the mention btw. Since I've already got all the lines and connections I was thinking it would be easy to do in the future, looks like you've already found a great sized one, though I may want one with a bit less width and more length, I'll have to look into it.
Also, thanks for the info on the Mugen thermostat... waiting for mine to get here. I'm in TX, so I know exactly what ya mean about the temps.
1991 Stealth Twin Turbo
Mods: 13T turbos, Stillen downpipe, HKS Super Drager catback, Fidanza adjustable cam gears, UR flywheel, DXD-F, DSM sidemount intercoolers, front mount oil cooler, LS6 MAFT, DN Y-pipe, gutted precats, ported exhaust manifolds, Apexi AVC-R set to 1.0 kg/cm, Greddy BOV type S, Supra pump, and an Unorthodox racing pulley.
UTRacerX9 is offline   Reply With Quote
Old 11-23-2004, 11:02 AM   #18 (permalink)
CTheiss is an unknown quantity at this point
Trevor I have the opposite issue when it comes to oil Temperatures. It takes a long while for my oil temp to start to rise and then it usually only reaches 70 - 75C. I think this might be too cold. Isn't there a minimum oil temp? Keep in mind that my oil capacity in the engine is 10 quarts and this may have a bearing on the oil temp. Regards Chuck
CTheiss is offline   Reply With Quote
Old 11-23-2004, 03:34 PM   #19 (permalink)
Eric_VR-4's Avatar
Drives: 93 VR-4
from an oil pan? got any pics? I just bought the supercar pan and I only get 1.25 quarts more... 10 is crazy!
Old 11-24-2004, 12:22 AM   #20 (permalink)
Member in good standing
Jim Floyd Level 2Jim Floyd Level 2Jim Floyd Level 2Jim Floyd Level 2
TRD makes a 21.3 psi radiator cap that fits our cars.
Trevor,
Is there a part number to ask for when ordering ?
Jim Floyd is offline   Reply With Quote
