#141 (permalink) | ||
Between Shadow and Light
I don't freakin' think so. The mount points on the center bar are raised up higher than they are on the ES, the RT center garnish is thinner than the ES. Its not simply a matter of moving the body mount points (welding new ones) to install the bumper, you are talking about remolding the bumper to fit the mount points so you can keep the ES tails.
![]() Last edited by iceman_ii : 04-28-2007 at 06:45 AM. |
#143 (permalink) |
'91 6-Speed
![]() 1991 VR-4: Six Speed, 3g lifter, Brakes, Rims, Polishing, Powder coating, Custom LED Tail Lights... ![]() 1987 FZ600: 100% Powder coated, Rejeted/tuned... 1990 Civic |
#146 (permalink) |
Volunteer FireFighter
we need to mass produce these. especially for the stealth
![]() Mods- 4" Intake, Modded Throttle Body, Re-Grind Cam Shafts, Big Tyla's Ground Wire Kit, Eibach Pro Kit Lowering Springs, NGK Copper Plugs, Accel Thundersport 300+ Red Spark Plug Wires, 6000k HID Kit, 99 Garnish, Prosport Gauges, Evolke 17" Wheels, Hella Optilux Fog's, Custom Exhaust, Clear Corners |
