car PC how to help - 3000GT/Stealth International Message Center
Old 04-20-2010, 01:32 PM   #1 (permalink)
Banned
Drives: 95 vr4
dpartinvr4 is an unknown quantity at this point
Feedback Score: 1 reviews
Default car PC how to help
one of my teachers gave me a 2001 dell dimension 8100 computer that I want to turn into a car PC to datalog my 95' vr4. I can make a new tower out of aluminum sheet metal, but what do I need to install on it to get it to work with my eonon 1012e 7" touch screen. I'm assuming evoscan 2.7, but idk how the touch screen thing will work, and what to do about the resolution difference.
dpartinvr4 is offline   Reply With Quote
Old 04-20-2010, 01:47 PM   #2 (permalink)
Slow Learner
x2xtreme360's Avatar
Drives: Like a German
x2xtreme360 Level 1x2xtreme360 Level 1x2xtreme360 Level 1
Feedback Score: 17 reviews
Default Re: car PC how to help
You really can't make a car PC out of a full ATX mobo. Most guys use mini ATX mobo and a VroomPC case or equivalent.
My rig is fitted inside a VroomPC case and a DC to DC converter as your power supply. The system is tied into your cars electrical so you can't use a conventional PC PSU.
The touch screen plugs into the PC just as a desktop one does but it's a touch screen. Only difference.
A great site to read would be http://www.mp3car.com/
Vacuum reduction, Powdercoated misc, cruise relocate, Evo9 BOV, Custom catch cans, Russell fuel filter, SS braided fuel lines, High flow fuel loop, Autogage fuel gauge, Catless DP, DNP Y-pipe, Fuel pump hotwire.
FS/FT: 94 3000GT base $3k
x2xtreme360 is offline   Reply With Quote
Old 04-20-2010, 01:50 PM   #3 (permalink)
Banned
Drives: 95 vr4
ok...but all my stereo has as an input is aux rca...how will the comp recognize the touch as an input....Im not exactly up to speed with my input device knowledge. and also all I want to do is datalog with it, so will it be that bad if i use a full size mobo?
Old 04-20-2010, 01:51 PM   #4 (permalink)
Banned
Drives: 95 vr4
i'll install all the software, then pull out the parts i need and install in a smaller size box i can make out of aluminum sheet
Old 04-20-2010, 01:54 PM   #5 (permalink)
Slow Learner
A full size mobo is going to have fitment issues. It's way to large and unstable inside a car. Your touch screen will plug into the pc via AGP or DVI just like a conventional desktop PC. You output the sound from the PC sound card through an 1/8" stereo jack Y cable with RCA jacks on the other ends. That will go to your amp.
Old 04-20-2010, 01:55 PM   #6 (permalink)
Ferriolom's Avatar
Drives: 1991 Stealth R/T TT
Ferriolom is an unknown quantity at this point
Feedback Score: 3 reviews
Your doing it wrong. Go to mp3car and read
Ferriolom is offline   Reply With Quote
Old 04-20-2010, 01:56 PM   #7 (permalink)
Slow Learner
The ATX mobo is not what you want to shoot for. The PC you listed came with 256MB of ram so that will need to be upgraded.
I'm not saying it definitely WONT work, but it's going to be a tight fit.
Plus, a 1.7 P4 CPU is outdated. The entire PC is outdated. I doubt it's going to be powerful enough to do what you want it to do.
Old 04-20-2010, 02:19 PM   #8 (permalink)
Banned
Drives: 95 vr4
that's really too slow just to data log?...I'm not trying to sound like a dick, but if I wipe it clean and clock it, I don't think it will have a problem, and the box is going where my trunk buckets used to be. so space really isn't an issue.
Old 04-20-2010, 02:40 PM   #9 (permalink)
Banned
Drives: 95 vr4
and I'm not going to run a sound card to reduce the power draw, but the stereo doesn't have a dvi or agp plug in? so I guess that's where I'm confused as to how the screen will work.
Old 04-20-2010, 02:41 PM   #10 (permalink)
Slow Learner
Hey man, it was your question. All I did was answer it. I build all my computers so it's not like I don't know what I'm talking about.
What OS you running? minimum of 512MB if you're going to run XP. If Vista or 7, I wouldn't use less than a gig. That PC you listed can support up to 2 gigs. I would max it out. Hell, I run 4 on my desktop. The 2 that my laptop comes with makes the PC usable with Windows 7 but I wish it had more. A lot goes on when you run datalogging software.
You need to make sure the components are going to be safe in the trunk. You can't have heat and you can't have bumps. Once again, ATX mobo's were not intended to be used in cars.
