Old 12-22-2007, 07:32 PM   #11 (permalink)
digger is an unknown quantity at this point
Default Re: AC/Heat: Full blast or nothing.
Hey im having the same problem. can someone post the location of the transistor fan blower pack and maybe what it looks like. i took my gloove box out and found a round relay at the bottom of the heater by the passengers feet that was held in place by a clip. i unplugged it and now my fan doesent work at all. Is that it? any help would be appreciated
Thanks Joe
digger is offline   Reply With Quote
Old 12-23-2007, 03:00 PM   #12 (permalink)
L_P
Woot!
L_P's Avatar
Drives: '95 Dodge Stealth TT
Trader Rating: (29)
L_P is an unknown quantity at this point
Thanks Joe
The relay is the high speed relay for full speed running.
I will post up the location here give me a few minutes to get the picture.
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid front and rear engine mounts, 3" Straight pipe exhaust single out.
Looks: DCC Conversion, White face glow gauges.
Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU.
Myspace
Must go faster project underway.
L_P is offline   Reply With Quote
Old 12-23-2007, 03:12 PM   #13 (permalink)
L_P
Woot!
L_P's Avatar
Trader Rating: (29)
In the Location picture it is number (3) this also shows you where it is located.
In the other picture this is what the part looks like once you take it out.
Let me know if you have any questions.
Old 12-23-2007, 09:21 PM   #14 (permalink)
Ok I found it, thanks for posting its location. now do you know were i can get a new one and maybe how much it is.
Thanks Joe
Old 12-24-2007, 03:28 AM   #15 (permalink)
xxnightraven73x's Avatar
Drives: 94stealth99silverado
xxnightraven73x is an unknown quantity at this point
if the blower motor only works on high 99% of the time its the blower motor resistor its hardly ever a bad motor or anything like that
94 stealth black with red,white and charcoal interior. sohc k&n intake,accel wires,custom 3"cat back dual outlet with dual 4" tipped n1 cans.17" gunmetal exel wheels,michelin pilots,kenwood cd player,audiobahn 1600watt amp,robo headlight mod ... more to come hopefully a tt swap funny in 4 months ive driven the car once (home) but its fun as hell throwing shiny parts at it lol
xxnightraven73x is offline   Reply With Quote
Old 12-26-2007, 03:57 PM   #16 (permalink)
L_P
Woot!
L_P's Avatar
Trader Rating: (29)
Thanks Joe
Ebay or look for someone parting out the entire car here on 3SI.
I think a new one can be had at the Stealership but I do not know how much.
Old 12-26-2007, 03:59 PM   #17 (permalink)
L_P
Woot!
L_P's Avatar
Trader Rating: (29)
If the blower works on high... then the blower works.
Old 12-26-2007, 04:52 PM   #18 (permalink)
well some people think its the motor if it only works on high but the resistor controls the fan speed. i dont know why you felt the need to post that but hey good for you
Old 05-15-2008, 09:03 PM   #19 (permalink)
Buck Waller is an unknown quantity at this point
I am a new owner that had this same problem and fixed my transistor pack. I am in the electronics industry and found that with mine the transistor thermal grease behind the transistor was dried up so there was not good heat transfer from the power transistor to the heatsink. This caused the large power transistor to burn up. The original transistor used was a Toshiba part that is now obsolete so I used a 25 amp part that I use at my company. It cost me $1.50 to replace this part and put thermal grease under the transistor to avoid a repeat of the problem. I can give more details to anyone who is looking to fix the same problem.
Buck Waller is offline   Reply With Quote
