#1 (permalink) |
Excitable at high speeds
I want my meth to turn on when I exceed XX psi of boost. What I was hoping to do was connect my EMS to the control unit of the meth and after the load exceeds XX psi the EMS would send out a +12V signal. That signal would turn on the control unit for the meth, and soon after, the trigger point on the meth controller would be met with a certain load (XX psi + Y psi) and start the meth injection.
Will this work? Can the EMS send out a 12V signal? What's a better way to turn it on? I don't want any extra switches that I could forget to turn on or off. Right now, my AEM Truboost has a built in switch for changing my boost setting. I want that to be the only switch I need to turn the meth on or off.
She's my little duece coupe....You don't know, what I got...
#4 (permalink) | |
#5 (permalink) |
New project in the works
You still might want to run it thru the aem for additional tweaking. Sometimes meth injection can throw off desired fuel delivery and timing values, which are easily adjusted thru the nitrous maps, like mentioned above.
-Josh
mildly modified blue 93 rt/tt-SOLD 3780lbs, pump gas 3/s. 127.08mph-92 octane. I still tune cars! new project, T.B.A |
