Old 04-05-2008, 10:08 AM   #1 (permalink)
gipper72488's Avatar
Drives: dodge stealth
gipper72488 Level 1gipper72488 Level 1
Default tuning a NA
i have a 93 sohc. im realitively new to the tuning aspect of modding and was wondering what could be done to tune my motor?
I <3 booost
93 sohc-sold
90 gsx-purchased 6/5/08
3 inch turbo back exhaust
valve job, ported head
MBC set at 14psi
gipper72488 is offline   Reply With Quote
Old 05-24-2008, 05:29 PM   #2 (permalink)
Turbo Lover
edhead81's Avatar
Drives: '92 Dodge Stealth TT
edhead81 is an unknown quantity at this point
Default Re: tuning a NA
I'll chip in on this dead thread. Perhaps the single mod I did when I had my old Saturn SC2 (yes, a Saturn) was get a S-AFCII and did some A/F tuning on the dyno. I leaned the A/F at WOT to 13.5:1 and gained 8WHP (that's over a 6% increase) and just as much torque, all above 3500 RPM. The stock A/F was dipping down to about 11:1 at WOT, way too rich for N/A.
So, A/F tune that sumbitch and maybe bump up timing a hair. I'm not sure if playing with A/F will change the timing (more advance when leaned out due to altered MAS signal fooling the ECM) since you have a distributor and not coil packs.
edhead81 is offline   Reply With Quote
Old 06-19-2008, 04:40 AM   #3 (permalink)
aquickfive0 is an unknown quantity at this point
is there a place around greensboro NC that tunes 3s
aquickfive0 is offline   Reply With Quote
