Old 04-02-2008, 04:24 PM   #11 (permalink)
echo9's Avatar
Drives: 1993 VR4
echo9 is an unknown quantity at this point
Default Re: tuning a 94 stealth base basics
never heard of hitting the breaks for 30 sec??
Originally Posted by Purdue3KGT View Post
I think you mean just disconnecting the negative battery terminal and stepping on the brakes for 30 seconds?
If so that just resets the fuel curves for the ECU. After driving for a day or two, the computer will re-learn the way the car is using fuel with the new upgrades.
Dynamic Racing Stage II Heads, 15G TD04L Turbos, DSM SM Intercoolers, HKS SSQV BOV, K&N Air intake filter, DNP intake Y-pipe w injection port, Blitz Duel SBC Boost Controller, ACPT Carbon Fiber Drive Shaft, DENSO 550cc Injectors, Denso (Supra) fuel pump @ 43psi, Split Second Arc2 Fuel Controller w GM maf, Fuel Lab Adjustable FPR, Autometer Fuel gage on rail with loop upgrade, Magnecore 8.5mm spark plug wires, Snow Performance Methanol Injection with spray indicator led, Prosport Boost, EGT gauges
AEM UEGO Controller with Wideband O2, Cianci Custom hand made 3-pillar gauge pod, G-force steel braided brake lines, ATR downpipe, Greddy Single Shot Exhaust, NGK copper plugs, PWR aluminum radiator, RPS aluminum flywheel, RPS Stage III clutch
Polyurethane Motor Mounts, 3sx steel braided turbo oil feed lines
I love the smell of boost in the morning.... smells like.... VICTORY!!! - Apocalypse now
echo9 is offline   Reply With Quote
Old 04-02-2008, 04:40 PM   #12 (permalink)
Forum user
raven1231's Avatar
Drives: Singleturbo3k/Z31T
raven1231 Level 1raven1231 Level 1
AEM on an NA lol
Built and Tuned By RUSH6432,IPS motorsports and myself.
Currently 384whp@wategate 6.8psi
Weight=2890lbs
Tials are in Dyno pull on the way pushing for 10-13 on pump and 15-18 on meth or race fuel....hell maybe even run both and go for 19-22
raven1231 is offline   Reply With Quote
