#1 (permalink) |
First, long story -short;
I have been fighting a rich idle condition for while,and decided to play around with Fixed SAS and BISS screw to see if I can adjust it out.....well I am getting close,but had a few issues: 1) IAC counts go to ZERO when warmed...this is even after adjusting per the manual. IAC seems to function normally otherwise...bumps up with steering input,AC,etc...coil also test good with multi-meter per manual... Question: what would cause this? 2) Also, I have to adjust idle to 900-950 range to accomplish 14.7 @ idle...don't like this, but seems to be a "is what it is" thing... 3) Now when coming to a stop, idle hovers at 1600 then eventually drops to the 950...annoying, and Im sure has something to do with the adjustments I made...tried to back off the dashpot a bit, but seems about the same...throttle cable seems fine.... Any ideas ? Any input apprciated! Thanks!
1992 Stealth RT/TT:
#3 (permalink) |
Gear Head
I take it you could not tune it lean enough with the MAFT with out messing up the rest of the tune? How rich is "rich" anyway?
1) Your IAC counts are being effected by the setting of your BISS and MAFT. Regaurdless of what you want the ECU is going to adjust the IAC to get what it wants to see. It wants the engine to idle around 800-875 rpms and will adjust the counts accordingly. 2) Sounds like your ECUs fuel trims are maxed out. The source of all of your AFR concerns. Do you have anything to adjust fuel pressure with? If so, what is the base fuel pressure at now? 3) The dash pot is to help prevent stalling and sergeing when the throttle is closed. The higher idle should happen normally, but it shouldn't be that high. If we can get your other concerns squared away, that should resolve this problem as well.
250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
#4 (permalink) | |
#5 (permalink) |
Gear Head
What are the IAC counts when the car is cold? Have you checked the IAC port to see if it needs cleaning? It looks like the ECU is trying to get more air into the engine but just can't do it. Maybe a leaking injector? Try a fuel pressure leak down test. On a side note, do you have any head work done?
#6 (permalink) | |
Injectors passed leak down test at Cruzin Performance (twice)...btw, there is a debate going on behind the scenes on whether or not EVO 8/9 injectors cause a rich idle, because it seems to be fairly common....although one could attribute that to the fact that alot of people are using them - not sure... Head work? yes, I ported/polished the heads when I had the VSS and guides replaced, but the problem was there before, exactly as it is now.... |
#7 (permalink) |
Gear Head
Replaceing the IAC wouldn't change anything. It is letting in all the air it can but you are still too rich. You need some thing to adjust the AFR at idle like an SAFC. But don't gett a NEO SAFC, every car I have seen with one of those has a really odd fuel curve that can't be tuned out.
#8 (permalink) | |
#9 (permalink) |
Resident mad scientist
what are your trims?
what is your fuel pressure at idle? what are your tune settings? what is your output frequency at idle? the hanging idle is most likely the dashpot.
Need a datalogger? Check out the Scanmaster 3
PM me about ECU mods for 8000+ RPM rev limits !!!!!!!! Stock = 7300 RPM Stage 1 = 8060 RPM Stage 2 = 8200 RPM Stage 3 = 8400 RPM Stage 4 = 8800 RPM (By request only) ![]() 1991 Stealth RT/TT, Grooms Shortblock, 13G's. My Stealth is for sale, 65000 miles, runs perfectly. $6,500 (a bargain) ![]() |
#10 (permalink) | |
