Old 06-21-2008, 05:48 PM   #1 (permalink)
Excitable at high speeds
stealthystu's Avatar
Trader Rating: (8)
stealthystu is an unknown quantity at this point
Default Suddenly Rich tune with AEM EMS
What would cause my untouched AEM EMS tune to suddely turn rich? The idle was 13.5 ish at about 900-1000 rpms, and now, with the same rpm, it's running at 10.0 to 10.8. Cruising has also gone down to 11.5. What happend?
She's my little duece coupe....You don't know, what I got...
stealthystu is offline   Reply With Quote
Old 06-21-2008, 06:11 PM   #2 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (209)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Default Re: Suddenly Rich tune with AEM EMS
Are you using O2 feedback?
Could be your WB took a dump.
AEM Factory Trained Tuner
91VR4 Black-5027s-3.0L-Stock heads and Cams- 707AWHP 620AWTQ uncorrected 30psi E85 Daily Driver
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
3SX Performance
3SX Performance Service Email
Import Power is online now   Reply With Quote
Old 06-21-2008, 06:42 PM   #3 (permalink)
Trader Rating: (8)
Is o2 feedback when the ems tries to mantain a specific afr? I don't think I am, but I don't really know. I was afraid I was because I started leaning out the fuel mixture and it would lean out and then go rich again. A non responsive tune from an AEM EMS is kind of ridiculous. I would believe it from a piggy back, but an ems shouldn't be nonresponsive. How could I check if the wideband went bad? It is kind of old, 2 years or so. Is it possible that one of my injectors is stuck opened? How could I check that? Thanks for the help. This is my DD and I'm a long ways from home and I have to get to work tomorrow :/
Oh, and I've tried using several different tunes that have all been fine as far as idle goes and they are all very rich now (~10.5)
Old 06-22-2008, 04:48 AM   #4 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
Trader Rating: (155)
BlackStealth Level 3BlackStealth Level 3BlackStealth Level 3BlackStealth Level 3
There's an option to turn on/off wideband o2 feedback control in the AEM EMS software. Look for that and make sure it's turned off, this will tell AEM EMS to ignore your wideband o2 results.
Also when my buddy's wideband o2 sensor died it gave out rich numbers so it's very likely just a broken sensor.
BlackStealth is offline   Reply With Quote
Old 06-22-2008, 04:54 AM   #5 (permalink)
Go To
Fuel>O2 Sensor Feedback>O2 Sensor Feedback
In the Options O2 Sensor Feedback see if O2 FBk Control is checked
You can also see what O2 sensor each injector is being controlled by under Options>injector
Old 06-22-2008, 07:41 AM   #6 (permalink)
Trader Rating: (8)
Awesome, thanks guys. I have to go to work now (in a borrowed car), so I will check it when I get back. What are the chances that it's an injector that is stuck opened? Can I turn individual injectors on and off with the EMS to help find the broken one?
Feedback was checked. I unchecked it but doubt I'll be able to use my car. It will likely change the driving characteristics because it doesn't have feedback control, right? If the car runs well and still reads way rich I think you're right that it's my wideband. I'll check it out after work.
Old 06-22-2008, 09:15 AM   #7 (permalink)
If the fuel map is tuned correctly, you shouldn't need to rely on O2 feedback to stay on target.
Old 06-23-2008, 05:14 AM   #8 (permalink)
Trader Rating: (8)
I've had trouble finding good tuners. The last place I went, Engine Logics in Texas, had my WOT set to 10.5 afr because they used their wideband, which they trusted. Funny, maybe mine was actually less accurate because it's potentially busted now, lol. I did have an exhaust leak which would cause it to be leaner at the tail end of the exhaust though. And they were dumb for a whole lot more reasons than just that.
Old 06-23-2008, 10:06 AM   #9 (permalink)
Trader Rating: (8)
I realized I could test the wideband by turning the car to the on position without cranking the engine over. The wideband turned on and was reading 14.8 without the engine being on. I'd say that settles it. I ordered a new wideband sensor for $65 + shipping
