Old 11-06-2009, 02:51 PM   #11 (permalink)
...feeling very depressed
inperfectdarkness's Avatar
Drives: m*f*ing time vampire
Trader Rating: (15)
inperfectdarkness Level 2inperfectdarkness Level 2inperfectdarkness Level 2inperfectdarkness Level 2
Default Re: Series 2 EMS soon
subscribed. this just MIGHT be what tips my hand at running AEM instead of a piggyback. cold/hot idle, etc were always worry points for me. this should cut down on tuning time significantly.
inperfectdarkness is offline   Reply With Quote
Old 11-07-2009, 10:54 PM   #12 (permalink)
Drives: Precision TIG 205
qksl2 is an unknown quantity at this point
Getting close guys. (Check out serial numbers)
Ian
FSR Motorsport Creations
Dyno reads high, track runs downhill, and its only fast when you launch it and you have to floor it to run a ten.
qksl2 is online now   Reply With Quote
Old 11-07-2009, 11:20 PM   #13 (permalink)
Gene's Performance
RussianVR-4's Avatar
Drives: 2002 TIsilver M3
Trader Rating: (18)
RussianVR-4 Level 1RussianVR-4 Level 1
oh oh! i wanna play with one!
02 TI silver/black 6spd 90k on the clock
KW V3's, Eibach 2way sway bars, Headers, AEM FIC, VMR V715's Michelin PS2's 295/35/19 rear 245/40/19 front. Boost inc.
RussianVR-4 is online now   Reply With Quote
Old 11-07-2009, 11:38 PM   #14 (permalink)
resident evil
wraith's Avatar
Trader Rating: (16)
wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2wraith Level 2
Can you explain some of the issues in detail the series 1 box has that this solves? My car idles pretty well, no different from stock, but it does have a few quirks which I thought was my tuning. For example after beating on the car, the idle revs dance up and down for a few seconds and then straighten themselves out. Also, I have hot start issues that I still had when I put the stocker back in which i think is related to the supra fuel pump or the fuel system since its the only thing that was modified when I put it back together. Are there any added features? Does automapping actually work on the series 2? Is igntion/knock control improved? From what your saying it has WB control built in? Will our base tune really be a plug and play this time around with everything setup to work right out of the box and just some WOT tuning needed?
Sam
wraith is online now   Reply With Quote
Old 11-10-2009, 03:23 PM   #15 (permalink)
Sam
Sam,
Can't go into detail right now (just because a million things happening in the shop) but I'll skim over stuff.
The bouncing idle is due to a lean spot in your VE map where the RPM's come back down "through". It won't be right where it idles, but it will be either above, below, or at a higher load value.
Don't use automapping.
Hot start issues are due to air in your rails, fuel vaporizing. You can do some target start vs temp tables that a good tuner will sort for you and you'll never know its there.
Knock control flexibility is improved, but if you are having a problem with series 1 knock control, most likely it is user error and not the system, and I don't mean that as an attack, it is just typically the case. I was at SEMA last week and the EFI University guy was pretty confused about it himself lol.
The previous base tune was very good, I have to finalize the new base tune for the box, which I am trying to do asap. However, again, it will be just for startup, not for driving on. It was never advertised, nor intended, nor will it be intended to be sold as a "tuned" box ready to drop in. That would be a million blown engines waiting to happen!
Ian
Old 11-10-2009, 04:10 PM   #16 (permalink)
Gene's Performance
Trader Rating: (18)
ian i cant wait to get my hands on one of them to play with it!
Old 11-10-2009, 04:44 PM   #17 (permalink)
I ♥ JDM Hoes Too!
10CentGT's Avatar
Drives: 3000GT
Trader Rating: (7)
10CentGT is an unknown quantity at this point
Originally Posted by niterydr View Post
I can't wait to see one of these in person!
You will have mine to play with
10CentGT is offline   Reply With Quote
Old 11-10-2009, 04:49 PM   #18 (permalink)
resident evil
wraith's Avatar
Trader Rating: (16)
thanks, your not offending me. I have been 'learning' slowly as I had to to solve things I did not like. My car has been a work in progress tuning wise for a couple years and there are still alot of options, I never touch. I am just a novice and trying to figure out if the new box is worth the cost of the upgrade from what I have.
Old 11-10-2009, 05:20 PM   #19 (permalink)
Gene's Performance
Trader Rating: (18)
im sure you could sell the S1 box for ~1200ish or so, after that it wouldnt be THAT much more to upgrade.
Old 11-13-2009, 12:01 AM   #20 (permalink)
The dark shall be with us
Devilmightcry's Avatar
Drives: 93' VR4
Trader Rating: (13)
Devilmightcry is an unknown quantity at this point
how does is compare to motec?
P.M me if you need new JDM MR final gear. $600+ shipping
Devilmightcry is offline   Reply With Quote
