Old 05-11-2008, 12:47 PM   #1 (permalink)
HLxDrummer's Avatar
Drives: 3000GT, '71 Mustang
HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6HLxDrummer level 6
Default Serial to USB Work for Hotsync?
Hey guys,
I know this has been discussed a lot but everytime I search people are talking about how they can't read info from the ECU. What the heck? I thought the converter was used to connect the Palm to a computer?
My laptop has a female serial port (I think to connect to another monitor) and my hotsync cable also has a female connector. Would a serial to USB converter work fine for this application?
What are people doing that the converters won't connect to the ECU, trying to datalog from a laptop?
Thanks!
1994 3000GT SL - Old Daily Driver SOLD
1993 VR4 with 150K miles - Daily Driver/Weekend Warrior/Sole Method of Transportation
Go: eBay Tanabe Concept G Blue Replica TBE, Metal Evo DV, Maximals TC Bracket, PST Two Piece Steel/Aluminum Driveshaft, Seattle STS, Solid Shifter Bushings
Monitoring: Palm M100 with MMCD, STRI X-Line Boost Gauge
Maintenance: 120K with oil pump and main/rod bearings, MSD 8.5MM wires, NGK Platinum plugs, Redline/Castrol Fluids, New ECU, Lowes Pressure Tester, New IAC/PVC/etc.
Show: '99 Garnish, Alan's Snake Eyes, Stealthy Wiper Mod, 3SX Aluminum Pedals
HLxDrummer is offline   Reply With Quote
Old 05-18-2008, 07:44 PM   #2 (permalink)
Gixxer Fixer
StealthCRF's Avatar
Drives: on empty
StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7
Default Re: Serial to USB Work for Hotsync?
Originally Posted by HLxDrummer View Post
Hey guys,
Thanks!
its an issue that comes up trying to log w/ a device that doesn't have a serial port and use a USB/Serial adapter. most adapters don't support the ECU's baud rate so only certain adapters may be used (certain model belkin or keyspans work great, the keyspan is vista compatible, the belkins are not)
92 Stealth RT/TT Best time: 13.2 @105
StealthCRF is offline   Reply With Quote
Old 05-18-2008, 07:53 PM   #3 (permalink)
Paid Member
Drives: 91 GTO SR
Trader Rating: (6)
kylejw Level 4kylejw Level 4kylejw Level 4kylejw Level 4kylejw Level 4
Theres a really good chance you're confusing a serial port with a VGA port here. If the port is for an external monitor, it will not fit a serial plug. If there are 3 rows of pins it's likely VGA, if there are 2 it's likely serial.
kylejw is offline   Reply With Quote
Old 05-18-2008, 10:09 PM   #4 (permalink)
HLxDrummer's Avatar
Ya, I have a VGA port (female/blue/3 rows) and no serial.
Stealth CRF: What do you mean by ECU? I assume the car's ECU but how come that would be an issue if the laptop is not communicating directly with the car's ECU (going through the Palm instead)? Basically, do people have issues connecting their Palms to the computers, or their car's ECU to the computers, or both?
Thanks a lot for your information, again I know it has been discussed but I don't get what the issue is and don't want to waste money figuring it out lol
Old 05-19-2008, 04:22 PM   #5 (permalink)
Gixxer Fixer
StealthCRF's Avatar
Drives: on empty
the problem I was explaining is when people try to connect the car to the computer that does not have a serial port. the usb to serial adapters don't work for the most part (usually they will connect but won't log data)
Old 05-19-2008, 08:49 PM   #6 (permalink)
HLxDrummer's Avatar
Alright, I gotcha Thanks for the help!
