Old 04-02-2008, 03:20 PM   #1 (permalink)
echo9's Avatar
Drives: 1993 VR4
echo9 is an unknown quantity at this point
Default Scanmaster III + MMcd logger
I have a scanmaster III and mmcd...
when i do the "test" in mmcd its telling me that the comm is good..
both set at 9600
but when i go to monitor .. no data is coming???
what gives.... i heard that the ignition must be turned on then the palm
then run mmcd?? does this matter... i will try tonight..
am i just not doing something right??
nate,
Dynamic Racing Stage II Heads, 15G TD04L Turbos, DSM SM Intercoolers, HKS SSQV BOV, K&N Air intake filter, DNP intake Y-pipe w injection port, Blitz Duel SBC Boost Controller, ACPT Carbon Fiber Drive Shaft, DENSO 550cc Injectors, Denso (Supra) fuel pump @ 43psi, Split Second Arc2 Fuel Controller w GM maf, Fuel Lab Adjustable FPR, Autometer Fuel gage on rail with loop upgrade, Magnecore 8.5mm spark plug wires, Snow Performance Methanol Injection with spray indicator led, Prosport Boost, EGT gauges
AEM UEGO Controller with Wideband O2, Cianci Custom hand made 3-pillar gauge pod, G-force steel braided brake lines, ATR downpipe, Greddy Single Shot Exhaust, NGK copper plugs, PWR aluminum radiator, RPS aluminum flywheel, RPS Stage III clutch
Polyurethane Motor Mounts, 3sx steel braided turbo oil feed lines
I love the smell of boost in the morning.... smells like.... VICTORY!!! - Apocalypse now
echo9 is offline   Reply With Quote
Old 04-03-2008, 06:38 AM   #2 (permalink)
Resident mad scientist
TurboBob's Avatar
Drives: 86 GN 91 RT/TT
Trader Rating: (13)
TurboBob is an unknown quantity at this point
Default Re: Scanmaster III + MMcd logger
what baud did you set in the scanmaster?
did you select any data to monitor? You need to pick a few data items.
Bob
Need a datalogger? Check out the Scanmaster 3
PM me about ECU mods for 8000+ RPM rev limits !!!!!!!!
Stock = 7300 RPM
Stage 1 = 8060 RPM
Stage 2 = 8200 RPM
Stage 3 = 8400 RPM
Stage 4 = 8800 RPM (By request only)
1991 Stealth RT/TT, Grooms Shortblock, 13G's, Translator Pro, www.maftpro.com
TurboBob is offline   Reply With Quote
Old 04-03-2008, 03:57 PM   #3 (permalink)
echo9's Avatar
Drives: 1993 VR4
baud rate on both scanmaster and palm at at 9600
i also tried 19200
i have mmcd v1.6m
oh i need to click the variouse items.. eg: rpm, injp, knck, 02-r etc...
that was dumb... lol well the screen looks like it shld display the datas
once i click into new lol .... all this time i was like wtf?
ill try it after work...
nate,
Bob
