Old 01-28-2008, 04:29 AM   #1 (permalink)
sl3kgt's Avatar
Drives: 94 SL/91 300ZX TT
sl3kgt is an unknown quantity at this point
Arrow Reseting ECU?..need advice
Ok I'm looking into buying a 91 vr4 but the seller says theres "SRS" BATTERY " BRAKE OR ABS " lights are on..and says he got it checked and was told the ECU just needs to be reset..is it true?
what could be the problem...? thanks
sl3kgt is offline   Reply With Quote
Old 01-28-2008, 05:02 AM   #2 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Default Re: Reseting ECU?..need advice
Not reset, it just needs to have the code cleared. Of course if there is really an issue with the SRS system it will just come back.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 01-28-2008, 05:48 AM   #3 (permalink)
Forum user
beckerb's Avatar
Drives: Stealth RT TT
beckerb Level 2beckerb Level 2beckerb Level 2
Remove power (disconnect the battery for 20 seconds) then reconnect it. As pointed out above, if there is an issue the codes will come right back...
Not to old to have fun - yet ??? -
2007 Dodge SRT-8 Superbee
2007 Hemi Quad Cab 4X4
2006 Harley V-Rod , 1999 S&S 1200 Sportster
2005 H/D FatBoy(Stage II),1973 BMW R75/5 restored
2004 Ducati Monster SR2,1972 BMW R75/5 restored
2004 Ford MACH I Mustang, Pro-Charger 535 RWHP
2002 Viper SRT-10,2000 Custom 883 Sportster
1992 Stealth RT TT (Stage III) 633.9 AWHP
1992 Stealth RT
1991 Stealth RT TT
and More
beckerb is online now   Reply With Quote
Old 01-28-2008, 10:37 AM   #4 (permalink)
keithmac Level 2keithmac Level 2keithmac Level 2
SRS uses it`s own computer, probably a clockspring fault (I`m sure you have to get this reset at the dealer?). Battery light means it`s not charging, ABS uses it`s own computer and probably has a wheel sensor fault.
JDM GTO TT, Emanage Blue - 450`s
Hotwired Walbro - K&N - Blitz SSBC
Port Methanol Injection - E85 - 12.4@115
keithmac is offline   Reply With Quote
Old 01-29-2008, 06:57 PM   #5 (permalink)
sl3kgt's Avatar
if the cars engine was swapped..does it make a difference?maybe thats why those lights are on..cus the ECU is not matching or something?i dont know?
bcus the seller changed the engine and has a JDM engine..same vr4
Old 01-31-2008, 04:16 AM   #6 (permalink)
None of the lights are from your Engine ECU, maybe he`s knackered some wiring under the hood for the ABS warning?, Airbag computer is under the centre console.
Old 01-31-2008, 05:17 AM   #7 (permalink)
sl3kgt's Avatar
Well I should be getting the car by next Friday..so lets see..
I really hope its nothing major though
Old 01-31-2008, 09:04 AM   #8 (permalink)
Moderator
Lord Warlock's Avatar
Drives: 2004 SVT Cobra,91TT
Trader Rating: (10)
Lord Warlock Level 7Lord Warlock Level 7Lord Warlock Level 7Lord Warlock Level 7Lord Warlock Level 7Lord Warlock Level 7Lord Warlock Level 7Lord Warlock Level 7Lord Warlock Level 7Lord Warlock Level 7Lord Warlock Level 7
The SRS light sometimes lights up when you let a battery die in the car...i mean let it go completely dead. The dealer actually has to reset it for you, unhooking the battery does not reset the srs light. It resets the ECU though if other lights are on.
Lord Warlock is offline   Reply With Quote
