Old 04-03-2008, 06:04 AM   #1 (permalink)
3000GT_Rider is an unknown quantity at this point
Default Reprogramming Stock ECU seems possible!!
Well I ran into this article under the 3000GT section, so I am assuming it applies to 3000GTs. I don't know the extent that this can reprogram.
Read: http://laurenstephens.net/uploads/4a81030ae5.pdf
3000GT_Rider is offline   Reply With Quote
Old 04-03-2008, 12:42 PM   #2 (permalink)
Default Re: Reprogramming Stock ECU seems possible!!
Anyone?
Old 04-03-2008, 05:25 PM   #3 (permalink)
Master Of Disaster
Gray Haze's Avatar
Drives: 3S's Since Feb 2002.
Trader Rating: (25)
Gray Haze Level 3Gray Haze Level 3Gray Haze Level 3Gray Haze Level 3
3000GT ECU is not EEPROM. Therefore its not programable.
The only exception to this seems to POSSIBLY be 1998-1999.
1992 3000GT VR-4 #15 of 24. The ORIGINAL Sandstone Gray '99 Conversion.
A slow strangle with your feet on the floor.
www.3stech.org - Now with 100% less invite codes! Free Registration!
Gray Haze is offline   Reply With Quote
Old 04-03-2008, 07:35 PM   #4 (permalink)
EEPROM or not, read the PDF. Aparently you can edit settings with the MUT-III
Old 04-03-2008, 07:53 PM   #5 (permalink)
Master Of Disaster
Gray Haze's Avatar
Trader Rating: (25)
I Know nothing about the 3S platform.
Old 04-03-2008, 07:57 PM   #6 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (42)
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
who gives a shit if you can?
Mail-in tunes suck. That is just what I want, someone else's tune that I can't even change. WONDERFUL.
Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops MAXED out, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, Polished Plenum and Valve Cover, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, 17" chromies, Nitto 555s
Drivetrain: RPS Street Max, M.W. 300m O/S
Etc: Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
JEDI MASTER SAFC NARROWBAND BASED TUNER, LORD OF THE DANCE ALSO
cbehnken is offline   Reply With Quote
Old 04-03-2008, 08:26 PM   #7 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
no gray we dont.
some obscure website just pwnd us and proved us wrong.
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
Old 04-03-2008, 11:36 PM   #8 (permalink)
Well instead of just making a smart ass comment, can you explain what that PDF means then? Did you even read the PDF? Is it just a big lie that government put out?
All I am looking for is an inteligent explanation of what the MUT-III can do as far as changing settings, IN ACCORDANCE with that guide. It's not an obscure website, it was a TSB put out by mitsu
Old 04-04-2008, 12:02 AM   #9 (permalink)
gearheadvr4's Avatar
Drives: Pucking VR4
Trader Rating: (24)
gearheadvr4 is an unknown quantity at this point
Nice find on the pdf. I did read thru the pdf and one major sticking point was the statement "all vehicles capable of PCM reprogramming"
I've seen it discussed a few times and it was shown that the ecu has read only chips. If they are read only chips, fixed set of instructions and programming... then you can't reprogram them. No matter what a pdf says. Even if it was possible I think those MUT-III are pretty expensive.
Gray get's a bit touchy when someone questions him but I'd pay attention. He knows his st*t on these cars. This has been looked at before. Either way I agree with cbehnken, I want to have control either with a piggy back or AEM. Stuff that I can program and change myself. I know a guy at work that owns a VW turbo beetle. He sent his ecu in for programming to go with the kit they sold. He wants to upgrade a few things but he's not sure if he can now since he has zero flexibility with his tune.
Permanently broke! But her soul will be reborn into another VR4 soon. 92 VR4- Rebuilt engine with forged crank, TD05 manifolds with MHI EVO 3 16g, 6 speed conversion done, Maximal Solid Mounts, front mount 3" w/custom intercooler and intake pipes, OFE Stage 3 Clutch (from Southbend Clutch), SS clutch line, SS brake lines, SS oil and coolant lines, borla exhaust, stillen downpipe, egr block-off plates, LC-1 Wideband, blitz dc2 turbo timer, hks ssbov, Maft Pro speed density, Blitz SBC i-D III boost controller w/ Power Meter, k&n filters & custom intake pipes, gutted cats, 18x9 blitz type 03 wheels wrapped in Nexen N3000 tires, intrax springs, adj. control arms, 97 frontend and side conversion, 99 center tail light piece (<--adds at least 20hp on the dyno )
gearheadvr4 is online now   Reply With Quote
Old 04-04-2008, 06:02 AM   #10 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
Trader Rating: (151)
BlackStealth Level 3BlackStealth Level 3BlackStealth Level 3BlackStealth Level 3
As Gray Haze already mentioned, only 98-99 models can be reprogrammed. The older 91-97 models cannot.
BlackStealth is offline   Reply With Quote
