Old 04-08-2008, 11:19 AM   #1 (permalink)
3000 lover
mikesx4911's Avatar
Drives: 91 VR4
Trader Rating: (7)
mikesx4911 is an unknown quantity at this point
Default Problem with using HHH and connecting to ECU HELP PLZ
Is this the way its supposed to be pluged in? Because I can not connect to the ecu
mikesx4911 is offline   Reply With Quote
Old 04-09-2008, 05:47 AM   #2 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
Trader Rating: (151)
BlackStealth Level 1BlackStealth Level 1
Default Re: Problem with using HHH and connecting to ECU HELP PLZ
That DB9 black cable between the Belkin adapter is not necessary.
I noticed that you required a DB9 gender changer, this makes me believe your datalogger cable is wired for palm devices and not for notebooks. If that is true, then you should replace your DB9 gender changer with a null-modem adapter. The null-modem adapter essentially swaps pins 2 and 3 around.
BlackStealth is offline   Reply With Quote
