Old 02-12-2008, 03:00 PM   #1 (permalink)
keithmac Level 2keithmac Level 2keithmac Level 2
Default Overrun fuel cut too aggressive?.
Anyone else find the overrun fuel cut too aggressive on these cars?, I`m thinking off adding a delay between when I shut the throttle and when the ecu sees the idle switch (maybe 3 seconds?) just to soften the transition between throttle and engine breaking a bit.
I was also thinking of dissabling the idle switch for 1/4 mile running, I don`t powershift and I`m sure the car cuts fuel between gearchanges making them harsher, longer to come back on the power.
Are the only factors for overun fuel cut idle switch on and revs over 1500 rpm or does the TPS come into play as well?.
JDM GTO TT, Emanage Blue - 450`s
Hotwired Walbro - K&N - Blitz SSBC
Port Methanol Injection - E85 - 12.4@115
keithmac is offline   Reply With Quote
Old 02-12-2008, 09:43 PM   #2 (permalink)
Resident mad scientist
TurboBob's Avatar
Drives: 86 GN 91 RT/TT
TurboBob is an unknown quantity at this point
Default Re: Overrun fuel cut too aggressive?.
check your dashpot.
Need a datalogger? Check out the Scanmaster 3
PM me about ECU mods for 8000+ RPM rev limits !!!!!!!!
Stock = 7300 RPM
Stage 1 = 8060 RPM
Stage 2 = 8200 RPM
Stage 3 = 8400 RPM
Stage 4 = 8800 RPM (By request only)
1991 Stealth RT/TT, Grooms Shortblock, 13G's.
My Stealth is for sale, 65000 miles, runs perfectly. $6,500 (a bargain)
TurboBob is offline   Reply With Quote
Old 02-13-2008, 03:44 PM   #3 (permalink)
I did the check via the manual (dashpot contacts throttle lever at 2200 rpm) my car nevet stalls out, seems to rest at 1000rpm and then drop to 700.
I set the idle switch as per the manual as well with the feeler gauges, might have a play around with both to find a good compramise.
I take it with a propperly set up working dashpot it gradually falls to idle from 2000 rpm then?.
Cheers for the pointer.
Old 02-13-2008, 11:05 PM   #4 (permalink)
TurboBob's Avatar
it sounds like your dashpot is working, that pause at 1000 sounds about right.
Old 02-13-2008, 11:30 PM   #5 (permalink)
king of ghetto
Highboosted's Avatar
Drives: '94 Stealth Turbo
Trader Rating: (29)
Highboosted Level 5Highboosted Level 5Highboosted Level 5Highboosted Level 5Highboosted Level 5Highboosted Level 5
Mine seems to act the exact opposite. It doesn't want to go into fuel cut/decel mode. just one of them things....
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
Official member of the "I upgraded everything in my car and now it's slower than stock" club.
Highboosted is offline   Reply With Quote
Old 02-14-2008, 01:02 PM   #6 (permalink)
TurboBob's Avatar
the software I am working on right now lets to trigger the fuel cut on decel more easily. I just need to tweak on it some more and then I can post it.
Bob
Old 02-14-2008, 04:46 PM   #7 (permalink)
Had a play with today and tested on the way to work, with it all set up stock (idle switch and dashpot) it was awful to drive, took far to long to engine break (throttle plate was been opened too long, not a fuel cut issue).
I wound the dashpot rod in 10mm from the first setup and set the Idle Switch to come in at the last possible point (not using the feeler gauge method), it takes 5 seconds from foot off at WOT to the idle switch activating, I thoink this will be near where I want it to be, or maybe another 5mm to 10mm wound off the dashpot rod will be needed.
Just goes to show you can`t always trust the manual to get the best setup everytime!.
Old 02-14-2008, 05:37 PM   #8 (permalink)
TurboBob's Avatar
the dashpot does 2 things
helps eliminate stalling, and softens the bump if you step off the throttle without pushing in the clutch.
let us know how it goes. I'll measure mine tomorrow.
Old 04-10-2008, 08:07 PM   #9 (permalink)
zalnn's Avatar
zalnn is an unknown quantity at this point
Any updates?
I have an 3000GT SL (not sure if its supposed to have a dashpot or if it was removed), and would really like to soften the fuel cut (rapid RPM drop) when stepping off the throttle.
zalnn is offline   Reply With Quote
