Old 01-19-2008, 10:51 AM   #1 (permalink)
elvis lives
elvis2007's Avatar
Drives: nails into my skull
Trader Rating: (11)
elvis2007 is an unknown quantity at this point
Default little knowledge needed ,, please..help
having a problem with fuel cut,,, i think,,, past 4000 rpm wot.
im running 15gs, 550 denso. walbro 255 hotwired. fpr, fmic, still running my maft. fuel pressure set at 40 lbs. no leaks i know of,, recently tested. base timing set at 3*. im trying to see if anything points towards a mechanical problem instead of and air, fuel, timing issue.
can i send a log to someone to check out for me.. im having a problem posting it on here.
my batt voltage is dropping to 13 volts about the same time it cuts,, no knock really,, maybe 1 or 2 counts at most. fuel trims running 99.8, not sure on fuel pressure, dont have an interior guage. injectors running 25.86 ms at 126%, then they drop to 0 on both counts for a second, then it picks back up again. at that point batt voltage was below 13.1 volts. this is all at tps 99.2%,, open loop.
maybe a fuel pump problem causing high idcs.??? this is where i get lost..
91 rt/tt, with lots and lots of mods done up poppa smurf style!!
elvis2007 is offline   Reply With Quote
Old 01-19-2008, 02:27 PM   #2 (permalink)
Master Of Disaster
Gray Haze's Avatar
Drives: 3500GT VR4/87 MCSS
Trader Rating: (26)
Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7
Default Re: little knowledge needed ,, please..help
your too rich @ WOT, or the boost is too high.
1992 3000GT VR-4 #15 of 24. The ORIGINAL Sandstone Gray '99 Conversion.
www.3stech.org - Now with 100% less invite codes! Free Registration!
Gray Haze is offline   Reply With Quote
Old 01-19-2008, 03:07 PM   #3 (permalink)
elvis lives
elvis2007's Avatar
Trader Rating: (11)
well,, im only running 1 bar at the moment. at idle my o2 trim gos from 38 to 120 randomly,, and not like cycling,, it sets for a few on one,, then it changes. you can tell by the motor when it happens. same while driving..
when it drops out there is no knock,, so i dont think the boost is to high..
and my wideband goes from way lean to way rich alot,, 60 mph,, even throttle, you can see it change on the logger. no matter how much i lean it or richen it up. im trying to get a log posted.
Old 01-20-2008, 12:46 PM   #4 (permalink)
Master Of Disaster
Gray Haze's Avatar
Trader Rating: (26)
fuel cutting @ 14.5 PSI on 550s? Your either too rich, or
u have something causing you to HAVE to run rich.
Old 01-20-2008, 01:48 PM   #5 (permalink)
venik's Avatar
Drives: vr-4
venik Level 7venik Level 7venik Level 7venik Level 7venik Level 7venik Level 7venik Level 7venik Level 7venik Level 7venik Level 7venik Level 7
what plugs are you running and what gap? how many miles on them? running lean for an instant or alot usually means spark blowout, cause the air isnt being burnt
1993 Pearl White VR-4 twin 16g
venik is offline   Reply With Quote
Old 01-20-2008, 02:00 PM   #6 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7
I had htis problem with a stock FPR and hotwired 255. Aftermarket FPR and change your fuel filter. Also seeing as your 1g, check your ecu caps while your at it.
Coop
To many mods to list.
Old 01-20-2008, 04:49 PM   #7 (permalink)
elvis lives
elvis2007's Avatar
Trader Rating: (11)
o.k.,, i have an aftermarket fpr with the pressure set at 42lbs. and a new oem filter. i changed to an ecu i know is good, and no change..
i did notice tonight that when i hit cut,, no matter what boost or a/f im running, the batt. voltage drops from 14 or so to 13 or below..
i might change the fpr to another to make sure its not bad..
but as of this moment,, im stuck..
btw,, after changing the ecu,, with the same settings on the maft,, the car is running pig rich. low trim 89.8...high trim 96.8... 02 trims at 100-120.
im still noticing the o2 trim jumps from 120 to 32.8 alot. it will do this at idle with no pedal also..
i like my car to much to shoot it,, so shoot me instead......
Old 01-20-2008, 07:46 PM   #8 (permalink)
elvis lives
elvis2007's Avatar
Trader Rating: (11)
o.k. new issue.. quick ride tonight to check things and i get an o2 cel,, and a #42 speed sensor cel. my o2 trims are leveling out but still rich. im gonna adjust and check again tommorow. maybe itll come to me in a dream,,,,
Old 01-20-2008, 08:19 PM   #9 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
Have you pressure tested?
Coop
