Old 10-05-2007, 07:38 AM   #1 (permalink)
ZERO's Avatar
Drives: '91 VR4
Trader Rating: (33)
ZERO Level 1ZERO Level 1
Default Installing ARC-2, do I keep my SAFC-II?
Well the question is im installing the arc-2 with 87mm, and I already have the apexi safc-2 should I keep the afc for even finer tuning or pull it? Is there any since in having two fuel controllers hooked up? I read on stealth316 that he has them both so thats why im asking.
'91VR4 w/19t's,550ccPTE's,SP Water/Meth Inj.,AeromotiveFPR,SAFCII, Apexi S-ITC,Denso FP hotwired,Scanmaster3 W/Palm&MMcD,GReddy FMIC,KoyoRadiator,Dejon Intake Pipes,K&N FIPK,Spec3+,RPS Lightweight F/W,PST-CFDS,Maximal Perf.T/C Bracket,Stillen DP,Borla CatBack,Meagan Coilovers,Powerslot Rotors w/EBC Pads,3SX SS,Brake Lines,HKS bov,HKS turbotimer,AEM UEGO, AEM TruBoost, short shifter,EGR block off & vac.reduc,CruiseControlDelete,MOMO steering wheel,MOMO racing pedels,MOMO shifter,Alum Dash Vents,ect.ect.
ZERO is offline   Reply With Quote
Old 10-05-2007, 07:46 AM   #2 (permalink)
''the professor''
i3igpete's Avatar
Drives: GoPigGo v2.0
Trader Rating: (72)
i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7
Default Re: Installing ARC-2, do I keep my SAFC-II?
i have an afc stacked on top of my map-ecu, but that's just so i can make adjustments without pulling out my laptop. with an arc2, i don't think you'll need it since it's just 4 knobs and you can easily change it by hand.
Maddog Performance Engineering
we will jack up your car on the oilpan and send a 9b through the windshield
i3igpete is online now   Reply With Quote
