Old 09-01-2008, 07:24 AM   #1 (permalink)
3KGT2NV's Avatar
Drives: 1994 3kgt vr-4
Trader Rating: (16)
3KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 7
Default installing aem ems
I picked up a used unit and had AEM go through it and was going to have Ray P install it and tune it but recent money issues have changed that and I would like to install it myself.
Here are my questions
#1 I want to use speed density so where should I locate the aem ait sensor and the aem 5 bar map sensor? I also have a aem boost sensor that would need to be installed also.
#2 Is the aem base map decent enough to start the car to rough tune with?
#3 With very limited knowledge of tuning am I going to kill my car worse with the ems than I currently am running an apexi neo?
Any help would be welcomed.
3KGT2NV is offline   Reply With Quote
Old 09-01-2008, 07:44 AM   #2 (permalink)
Senior Member
defgh1's Avatar
Drives: 99 VR4, 04Volvo V70R
Trader Rating: (8)
defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7
Default Re: installing aem ems
1. I located my AIT in the Y pipe prior to the throttle and the map sensor in the driver side rear of the intake manifold.
2. Car eventually started, but I found the base map to be overly rich.
3. With limited knowledge you really need to find an experienced AEM tuner. Beside the Map, the number of possible settings on the AEM can be mind boggling and just one adjustment can make a big difference on how the car runs. In addition, every car combination is different and I found other peoples maps, even with similar set-ups, worked poorly on my car. You should plan on around 3+ hours of dyno time with a tuner to get you car right. Once you get the basic tune set then minor tweaking is pretty straight forward.
Doug H
91 Sandstorm TT, 431 AWHP, 433 ft-lbs. , Kormex 25 spline,LSD, RPS CC Clutch, 4 bolt conversion, Super 15Gs, Stage 3 heads, DSM Sidemounts, PST Driveshaft, Blitz DSBS, HKS Exhaust, 3SX Downpipe, Supra Pump, 780 cc PTE Injectors, SX Fuel reg. & dual feed, AEM, Duel WJO Wideband, HKS DL1, Alcohol Injection. Photos: -->
defgh1 is offline   Reply With Quote
Old 09-01-2008, 08:01 AM   #3 (permalink)
3KGT2NV's Avatar
Trader Rating: (16)
Yea I figured 3 hours of dyno time to get it tuned properly but I have a 2.5 hour drive to rays P. to get it tuned. so i was hopeing to have it installed and driveable.
Mabey i will install all the sensors and just switch the ems over once I get there.
Old 09-01-2008, 08:41 AM   #4 (permalink)
Senior Member
defgh1's Avatar
Trader Rating: (8)
You did not mention it, but a wideband is mandatory for a speed density set-up.
Doug H
Old 09-01-2008, 08:45 AM   #5 (permalink)
3KGT2NV's Avatar
Trader Rating: (16)
Here is a quick mod list for my car
SHORTBLOCK
-overbored to 3.1L
-new forged crank
-3sx ross pistons
-new berrings
-obviously all the gaskets are new
-60k service bundle for new pumps and suchnot
HEADS
-3sx stage 3 heads with +1/+1 valves
-streetweld race cams
-new gen 3 lifters
-new roller rockers (mine were rusted)
-new head studs
FUEL SYSTEM
-550 injectors
-apexi neo afm
-3sx fuel loop set up
-walbaro feul pump
-fuel hot wire kit
TURBOS
-3SXecutioners turbos
-3sx 10an oil lines
-rfl style bov
-turbo xs boost controller
COOLING
-3sx alum radiator
-new water pump
-all new sensors
INTERCOOLER SETUP
-Dejon tool FMIC with black pipes
DRIVETRAIN
-krankvent II
-fandanza flywheel
-spec III clutch
OTHER STUFF
-redline additive kit
-3sx msd plug kit (with custom wire color)
-new plugs
-polished plenum
-blue engine hose kit
EXHAUST
-dnp precat eliminators
-dnp full 3 inch exhaust
-random tech ultra high flow racing cat
Tires
-Moda r6 rims with khumo tires
-jic suspension
sorry for the long list but I cut and pasted from an old post.
I have an aem wideband already along with the other 3 sensors
