Old 03-07-2008, 03:15 PM   #1 (permalink)
keithmac Level 2keithmac Level 2keithmac Level 2
Default Idle switch wire colour and location at ECU plug?.
Hello, I`m doing some experiments with the fuel cut function on my 1st gen GTO. Does anyone know the pin location at the ECU for the idle switch?.
I`m having a look on Sunday but don`t get much time to work on the car so if anyone can help it`d save me some time. Looking at it grounding the Idle pin should turn on fuel cut?.
Cheers, Keith.
JDM GTO TT, Emanage Blue - 450`s
Hotwired Walbro - K&N - Blitz SSBC
Port Methanol Injection - E85 - 12.4@115
keithmac is offline   Reply With Quote
Old 03-07-2008, 03:28 PM   #2 (permalink)
'92 SOHC Stealth
SOHCStealth's Avatar
Drives: '92 SOHC Stealth
SOHCStealth is an unknown quantity at this point
Default Re: Idle switch wire colour and location at ECU plug?.
Cheers, Keith.
Should be pin number 67 on a 1st Gen TT and DOHC N/A.
'92 Dodge Stealth SOHC - 3SX Adjustable Camber & Toe Arms, Eiback Springs, KYB Struts, 3SX Steel Braided Brake Lines, Stillen Brake Pads on Stillen Cross-Drilled Rotors, 3SX Steel Braided Clutch Line, 3SX Lightweight Aluminum Crank Pulley w/ Gatorback Belts, 65mm Big-Bore Throttle Body w/ Half-Shaft Mod, ARP Head Stud Kit, 3SX Poly Motor Mounts, 3SX Short-Throw Shifter w/ Solid Shifter Bushings, 3SX 2.5" Downpipe, RT High-Flow Cat, Custom Stainless 2.5" Cat-Back w/ Flowmaster 40, 18" ADR SZ1 Wheels, Etc...
SOHC Single Turbo Project in progress.
SOHCStealth is offline   Reply With Quote
Old 03-09-2008, 03:34 PM   #3 (permalink)
Cheers, it`s the yellow wire with red stripe if anyone else is looking for it.
