Old 01-08-2008, 10:35 PM   #11 (permalink)
been there done that
niterydr's Avatar
Drives: Audi A6 2.7t
Trader Rating: (33)
niterydr is an unknown quantity at this point
Default Re: How to tune a car, step by step.
Originally Posted by spfan View Post
bravo. it's good to have all that info in one, very readable, thread.
only thing: i know this is nitpicking, but i just don't want a new guy to tuning reading this and getting confused. but duty cycle is actually the percentage of the time the injector is open in relation to the amount of time it can be open, correct? ie: at 100% duty cycle, the injector is open all the time. at 5% duty cycle, it is open 5% of the time. the rest it is closed. what you defined is actually the pulse width, correct? please correct me if i'm wrong.
but yeah,
I simplified it overly, thanks for the catch (I am still proofreading it).
Duty cycle= (pulsewidth)/ (total time between ignition events)
-Josh
3780lbs, pump gas 3/s. 127.08mph-92 octane. (2005, ~'480'awhp)
best dyno: 720.2awhp/592tq.
blue 93 rt/tt-SOLD (and missed on occasion)
new project, T.B.A
niterydr is offline   Reply With Quote
Old 01-08-2008, 10:59 PM   #12 (permalink)
Verified Asian
Sean3S's Avatar
Drives: 94 TT
Trader Rating: (37)
Sean3S Level 1Sean3S Level 1
Badass thread. And Josh FYI I *believe* that PTE uses Garrett cores.
'94 RT/TT
13T's | PTE FMIC - PPE Pipes | 560's | Supra FP w/ 8ga Hotwire | MAF-T 1.37 & LT1 Blow-Through | E-Manage Blue w/ Boomslang Harness | HKS DLI | Stillen Downpipe | Gutted Rear Pre-cat | Borla Catback | Tial BOV | AEM FPR & Rob Beck Adapter | DejonTool Intake Pipes | PWR Radiator w/ IPS Pipes | FAL Fans | MP Motor Mounts | 99 Lash Adjusters | Clevite 77 Rod & Main Bearings | Leatherseats.com Dk. Graphite w/ Red Center Seats | Sparco Flash 5 Black w/ Red Alcantara | Spec Stg. 2 Clutch & 3SX Clutch Line | 3SX Crank Pulley | Bob's SS Shifter & All Solid Bushings | eK2 EGR Blockoffs, Fuel Line Loop, Injector & Harness Cover | PST 1 Pc. CFDS | Volk LE37T | Falken FK452 | Megan Racing Coilovers | Adj. Rear Control Arms | Slotted Rotors w/ Hawk HPS Pads | GReddy Profec B | AEM UEGO WB | GReddy PWH Boost, EGT, GReddy OP, FP, Temp | Hybrid Logger | McColluch 5300K HIDs | Shaved '99 Bumper & Turns | PRM Style Hood
295.7 AWHP / 310.3 TQ @ 1 Bar - BPU @ TX04
Collecting Dust - Setrab Oil Cooler, Snow Stage 2 Meth, Brake Lines, Solid Diff Bushings
Some Day - ABS Delete, Ducting
Sean3S is offline   Reply With Quote
Old 01-09-2008, 12:02 AM   #13 (permalink)
niterydr's Avatar
Trader Rating: (33)
Yes PTE is in-fact a huge Garrett distributor.
Old 01-09-2008, 09:43 AM   #14 (permalink)
Indy here we come 06/2010
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2Alan92RTTT Level 2
If you see a post missing, I deleted several to pull Josh's together.
Better late then never? The 2009 3S Calendar
NG07 T-Shirts For Sale * NG08 T-Shirts For Sale
NG08 Stuff from Cafepress
Custom 12x18 poster/photo prints
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is offline   Reply With Quote
Old 01-09-2008, 10:58 AM   #15 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (56)
Hannibalzero is an unknown quantity at this point
It looks like the first paragraph of post #1 is missing too.
Old 01-09-2008, 11:25 AM   #16 (permalink)
Alan92RTTT's Avatar
Drives: 1992 RT/TT
If one of Josh's posts changed he did it. He did alot of changes from the original version of that post.
Old 01-09-2008, 12:00 PM   #17 (permalink)
niterydr's Avatar
Trader Rating: (33)
True story!
Old 01-19-2008, 12:38 PM   #18 (permalink)
Row faster!
WolfSL's Avatar
Drives: 92 VR4 & 98 SL
WolfSL is an unknown quantity at this point
I've got a question. How do you handle initial tuning on a freshly rebuilt motor? Particularly with a standalone like the AEM. I ask because a majority of the break in happens within the first hundred miles or so that you run the motor (at least that's my understanding) and obviously a bad tune isn't a good thing to break a motor in on. Do you just load up a base map (or come up with one on your own based on your experience), get AFR and timing values to good levels as quickly as possible and than continue with the break in of the motor? Or do you use some other methodology?
<-- How I plan on going fast
1992 VR-4 - It is being fixed (finally)
1998 SL - DD
WolfSL is offline   Reply With Quote
Old 01-20-2008, 11:41 AM   #19 (permalink)
H to the izzO
Drives: Recklessly
Trader Rating: (56)
Why not just use the stock injectors with stock ECU? Problem solved.
Old 01-21-2008, 01:48 PM   #20 (permalink)
niterydr's Avatar
Trader Rating: (33)
Myself personally I have enough base maps that I can have the car running/idleing/reving like normal/stock within 10 minutes, 99% of the time the car will be idling good and running great by the time the coolant gets to operating temperature.
Hannibal's suggestion is a good method to make sure the car starts okay if you don't trust yourself or don't have enough experience to get the car running clean on your first try.
