Old 03-28-2008, 08:26 PM   #11 (permalink)
Schurmia's Avatar
Drives: '91 3000gt VR4
Schurmia is an unknown quantity at this point
Default Re: How to...
I do have my Uego hooked into my egrt wire on my ecu and it is picked up and logged by MMCD but it's readings are off and it gets much worse as afr gets lower which is when it needs to be most accurate.
'91 VR4 - Construction Complete...
Schurmia is offline   Reply With Quote
Old 03-29-2008, 12:17 AM   #12 (permalink)
Can't say *****?
yellowgto's Avatar
Drives: 93 RT Turbo
Trader Rating: (10)
yellowgto Level 1yellowgto Level 1
That's the scaling issue. It's a really easy fix with the source code. Unfortunately clint did a lot of work after the last source code he released. You could go back to the older version if you wanted to though.
In Process: TD04HL 19T, 660cc, ARC2, EK2 Motor Mounts, RPS Max Clutch, RPS Flywheel, PWR Radiator, IPS Downpipe & 3" Catback, AEM FPR, HKS Sidemounts, ported manifolds/rear O2 housing
-Bye Bye Bomex -
94 stealth headlights & rear bumper are on, 99 front bumper/turns are on
Car is hiding in the garage waiting for paint!
yellowgto is offline   Reply With Quote
Old 03-29-2008, 03:37 PM   #13 (permalink)
Pearl White 92 Stealth TT
mike92stealthtt's Avatar
Drives: BPU 92TT
Trader Rating: (11)
mike92stealthtt Level 1mike92stealthtt Level 1
So are you saying that version 1.8 won't work with the Uego but version 1.6 will? Sorry I am a little confused here.
Mike
If you got a 96 stealth wing you want to sell please PM me.
mike92stealthtt is offline   Reply With Quote
Old 03-29-2008, 04:43 PM   #14 (permalink)
USMC
vr4_rider's Avatar
Drives: '93 Vr4; '06 675cc
Trader Rating: (10)
vr4_rider is an unknown quantity at this point
^^^ditto.
Trung [1993 Pearl Black VR-4]
Appearance//1999 Front end//ground controls w/ adj. rear control arms//18x9 5Zigen 5ZR wrapped in 245 front, 275/35/ZR18 Falkens//DR Racing Black lugnuts
Mods//GReddy EBC Spec-II//Greedy Type-S BOV//Unorthodox UD pulley//ATR Downpipe//IPS Single Shot Magnaflow//255 Walbro pump//GReddy Profec Spec II EBC//JET tuned ECU//AutoMeter Boost gauge//HKS Turbo Timer//Gutted Hi-Flow DynoMaxx CC//Vac Reduction//EGR Block off//PRO-M 80mm MAS and MAF-T Tuner//EVO 8 560cc injectors //Shriver's datalogger
Turbos: 13Tx2
Current Problem(s): Cherries in the rear view mirror
In the Process: Nothing
Want to Trade/Buy: Cams and springs, non-OEM clutch and flywheel...
vr4_rider is offline   Reply With Quote
Old 03-29-2008, 06:17 PM   #15 (permalink)
Schurmia's Avatar
Is there some reason nobody is able to get the source code from him for version 1.8?
It does look like version 1.6n should read the AEM Uego much better then 1.8...
Scaling for AFR input - Changed after 1.6N
Old 0-5V = 10.0 - 20.0 AFR
New 0-5V = 8.0 - 22.0 AFR
...Just switched over from 1.8g to 1.6n and looking thou previous logs and all air fuel ratios appear to be correct now.
Old 03-29-2008, 09:43 PM   #16 (permalink)
USMC
vr4_rider's Avatar
Trader Rating: (10)
Can you give me the link to 1.6 please
T
Old 03-30-2008, 08:55 AM   #17 (permalink)
Schurmia's Avatar
Here is the link for 1.6n.
http://www.3si.org/forum/attachment....chmentid=39998
Old 03-30-2008, 09:23 AM   #18 (permalink)
USMC
vr4_rider's Avatar
Trader Rating: (10)
THanks bud.
Obviously, there's a upside to switching to the 1.6n--being able to better read the UEGO.
What are the downsides of the 1.6n compared to the 1.8n?
Thanks,
T
Old 03-30-2008, 11:39 AM   #19 (permalink)
Schurmia's Avatar
Here is the update list of everything changed since 1.6n...
15-4-05: V1.8g
- First-time-user testing identified a number of usability issues
- Changed large numeric so it comes up visible the first time MMCd is run on a new Palm device
- Need to set panel select to default sensor
- Set default selectedSensor = IDX_RPM to solve panel sensor select issue in 4X display
- Removed break from 4X display loop so it always shows 4 sensors - ready to config
- Display "-" on sensors that are not enabled for scanning
- Test and release
15-4-05: V1.8f
- Released new version to 3SI
11-4-05: V1.8e6 testing
- Testing changes to increase logging speed by peaking QueryECU
- Added logic for easier sensor selection
- Flashing Reverse-Alarm-Peak-Hold
- Auto reset peak value on alarming sensor
- Added Select Indication on Large Numeric
- Change mS timing Hack to data[o] - was data[23] but was getting whacked by VSPD
- #define msDataHack 0 in MMCd -
- Revert back to 23 for log compatibility for now
- Change logic on shutdown to clear peak values to 0 and manually set COOL / AIRT entries
- Simplified logic by flagging powerdown case and setting MIN/MAX to curent on first scan
- Works like a champ
11-4-05: V1.8d Release to test
- Remove dead code in mmcd.c
- Added test struct at beginning of debug code for mem segments
- Also added test const declaration at start of debug.c to keep some memory in reserve
- Added non-linear Baro scaling to graph.c
- Added Numeric Reverse-Alarm-Peak-Hold
- Recovered space lost in large font file
9-4-05: V1.8d4-7
- Added test code for reverse alarm digits in 4X large digits
- Fixed bug where EGRT slug was not updating right away
- Fixed bug where Overclock was not being applied right away
- Fixed COOL/AIRT max after power down bug
- Auto reset using using scratch data for min/max instead of setting values to zero
9-4-05: V1.8c
- More tweaks to help system
- Release to 3SI
9-4-05: V1.8b
- Fixed small bug in variable % scaling
- Fixed description for ISC - Idle speed control bug in sensor info list
9-4-05: V1.8a
- Changed to V1.8 to eliminate any confusion with parallel DSM effort
- Added help info to Preferences and Alarm screens
- Remember to click on the "i" in the upper right hand of the dialog
- 4X slugs displays correctly on color and B&W Palms
9-4-05: V1.7K
- Fixed INJD Peak (too many hacks!)
- Changed to bold numbers in 4X display
- Removed units in 4X display to make more room
- Added reverse slugs in 4X mode
- Fixed scaling error in RPM
- Changed AIRT / COOL Metric units back to xx.x C format
- Changed % display format so < 100 displays xx.x % and > 100 displays XXX %
- Moved INJD to first bank and INJP to second page
- Misc mem trimming - project is REALLY out of space
- Appears that static VARS are not sharing code space
8-4-05: V1.7J
- Fixed AIRT Peak Polarity
- Fixed AIRT Alarm (Min/Max)
- (AIRT already graphing correctly from earlier fix)
- Started shell of dynamic allocations to free up some memory
- Found that "Prefs" var was being declared but never used (waste of static space)
7-4-05: V1.7I
- Fixed INJ scan bug (if INJD was last sensor it would halt scanning
- Brute force approach for now - will rip out INJD and provide scaling option in future release
- Added INJD logic to enabled RPM/INJP
- Modified 4X display logic so numeric displays can be configured while paused
6-4-05: V1.7Hcb
- Added non-linear O2 Graphing
- Added O2 Non-Lin Preferences option
- Fixed menus
- Added back in degree symbols
- Out of memory error if EGRT slugs enabled
4-4-05: V1.7fg
- Added overclock ECU logic (MAF / RPM)
- Added overclock baud rate for direct connect
4-4-05: V1.7f
- Fixed missing break in MMCd.C that was screwing up num/graph toggle (hiding sensors)
- Found / fixed bugs in new baud / overclock code
- Weird string interaction in MMCd baseTime code (used str2 work-around)
- baseTime has to be UInt32 otherwise weird things happened
- Consolidated MMCd.C init code into setDefaults()
- Powerdown reset clears Peak buffer
- Disabled DashALarm checkbox in alarm config
2-4-05: V1.7e
- Fixed Min/Max logic on Coolant Alarm setting (reversed)
- Fixed Min/Max logic on Coolant Peak / Hold (reversed)
- Switched large number diplay logic back to most recent always in upper left
- Peak automaticall reset after returning from power-down
- Hide mode works in review mode - slick
- Added 4 pt space to right of 4X text
- Fixed peak logic in simulation
31-3-05: V1.7d
- Disabled peak hold on large digit (always displays current)
- Fixed peak on INJD related to earlier INJD logic change in V1.6p+
- Fixed INJD logic (finally)
- Added persistant storage for 4X config
- Modified timing graph scaling (-10 before re-scaling)
- Changed power-down timing to 5 sec
- Cleaned up form display
- Reversed logic on big number selection
- Review / Hide logic - sensor list is now filtered by available sensors in period
- Fixed form corruption when selecting Preferences - Default
- Checked timing calculation for accuracy
29-3-05: V1.7cb-4x
- Fixed form bugs
- Added timing graph scaling
- Added 4X numeric mode (repalces 1X jumbo text)
- Need to review other changes between 1.6P and 1.7aa
6-1-05: V1.7ad
- Save state bug fixed
- Eliminated implicit declaration warning
3-1-05: V1.7ac
- Created "Custom Sensors" menu under "Options"
- Moved "Custom Sensors" code from "Preferences" to "Custom Sensors" menu
- Implemented 3/s or DSM vehicle select in "Preferences" to scale timing values
- Implemented user defined base timing value for those with non stock base timing
- Removed 1920 and 9600 bps from the "COM" list
- Added 2148 and 2246 bps to the "Com" list to communicate with overclocked ECU's
- Moved "Simulate" to the top of the "Com" list
- Disabled prototype "New" menu for public release
- Changed default mode for a new log to Monitor_Mode
- Made all sensors selected for scanning by default
27-11-04: v1.7ab
- Fixed bug causing MMCd to crash when connected to the car, or in simulate mode
- Fixed "chunk over-locked" error
- Fixed resources locked error when exiting MMCd
- Fixed bug where INJD would display data when RPM and INJP were selected, even if INJD was not selected
- Added new menus for visual evaluation
- Added SmartScan enable checkbox in System Config
- Added Vehicle Select to select DSM or 3/S to scale timing value
- Added option to select your base timing to compensate for those running non stock base timings, allowing the true timing value to be logged
19-11-04: v1.7aa
- Restored broken functionality
- Moved Units list to System Config
- Added Log Rate, Display Rate to System Config
- Revised Sensor Config form
- Removed Threshold label and replaced with sensor slug
- Alarm can be set from old Alarms, or new Sensor Setup
17-11-04: v1.7a
- Graphical revision of menu structure for evaluation purposes
12-11-04: v1.6p
- Fixed coimpiler directive for new sensors
- Preferences dialogue COM: list box now 5 high (less scrolling)
- Fixed INJD bug in mmcd.c
15-07-04: v1.6o
- Investigating delay in serial rec/xmitroutine
- Added default AutoLog = true
- Added compiler directive to build with/without new sensor definitions
- Changed AFR scaling to 8.00 -> 22.0 (limited testing)
- Fixed overwrite of Reset button in monitoring mode
- Changed Speed: to COM: (solved display crunch)
01-06-04: v1.6N
- Changed max knock to 32 in graph scaling routine
- Fixed upside-down temperature graphs
- Fixed bug in postlog
- Added 56K high speed baud rate for expansion interface
- Testing new sensor definition/scaling
Old 03-31-2008, 01:14 AM   #20 (permalink)
Can't say *****?
yellowgto's Avatar
Drives: 93 RT Turbo
Trader Rating: (10)
Well he never responded to me when I asked him if I could get the source code, and he doesn't appear to have ever responded to the other posts or PM's people sent asking about it. I'm not sure why he doesn't want to give it out.
