Old 04-13-2009, 10:57 PM   #1 (permalink)
Boost4VR4's Avatar
Drives: 97 VR4
Boost4VR4 is an unknown quantity at this point
Default HHH datalogger cable, OBDII VR4, and vista 64
I just got my HHH datalogger cable for the OBDII setups and I installed the software included with the cable on my Vista 64 bit machine. Software installed no problems, the cable drivers were a bitch to find, I had to download a vista 64 bit driver off of FTDI and bypass the vista drivers that it installed. I have a few questions: on an OBDII/hybrid ECU car, where is the OBDII connector? to the left of the center console? I plugged into that, and when I hook up the data cable, turn the key to on and fire up the software, the software doesn't pick up the ECU. Is there anything special that needs to be tweaked in the software to pick up the ECU?
Electronics:
Blitz Dual Turbo Timer
Audio:
Pioneer 6 3/4" 5 way, Pioneer 6"x9" 4 way, Pioneer 1 1/2" tweeters
Engine Appearance:
TiradoCustomCoatings Powdercoated Valve Cover, Twin Turbo spark cover, 3SX Plenum wire cover
Engine Modifications:
Dejon Tool Y-Pipe /w HKS flange, Dejon tool turbo runners, 3SX Mid-Splitter plug, HKS SSQV, Click-start mod
Interior
Autometer Dual Gauge Pod, Autometer Sport-Comp Boost Gauge, Autometer Sport-Comp Oil Pressure gauge, 2nd Oil Pressure Gauge, Oil Temp Gauge, Narrowband
Wheels:
OEM VR4 Wheels wrapped in Fuzion ZR1s
Boost4VR4 is offline   Reply With Quote
Old 04-28-2009, 10:13 AM   #2 (permalink)
I'm a Member
Drives: 1996 geteoh
MichaelMR2 is an unknown quantity at this point
Default Re: HHH datalogger cable, OBDII VR4, and vista 64
in the software you need to tell it what com port it should attempt to connect to, if you go into device manager and look down the list for ports, then look at the device that is the HHH cable, it should have a port number on it (mine is usually com3)...in the software you simply put this in and it should solve the last of your issues.
nice one on finding the drivers, I had the same pain.
FMIC is CRAP, CRAP IS CRAP, Jeff Lucius/1UZ-FE/VQ35HR Rocks, Privvy?
MichaelMR2 is offline   Reply With Quote
Old 04-28-2009, 10:38 AM   #3 (permalink)
Boost4VR4's Avatar
Drives: 97 VR4
I simply hate this cable, it doesn't work, I tried it in my F150 which is OBDII to eliminate the possibility of it being my diag port on my ECU in the VR4 and I ruled out the cable. The software is configured properly, I have tried every single baud rate I could on the com port, I have tried every single configuration I could think of, even picked up EvoScan and it didn't work. I am going to be talking to HHH for a refund since the cable is obviously flawed or it's the wrong one they sent me. The drivers did fix some of the issues I was having but overall, the cable doesn't work. Plus I could really use the money right now and the VR4 is still running, just wanted to figure out what my check engine light is from, really aside from that, it was just for preventative measures and a diagnostic tool that I thought would work out great.
Old 04-28-2009, 10:58 AM   #4 (permalink)
I'm a Member
Drives: 1996 geteoh
fair enough, I'm on the same OS, so I'll post up whenI get the car in once piece again
Old 07-10-2009, 02:36 PM   #5 (permalink)
airtimehocutt is an unknown quantity at this point
i just got this for my 99 vr4. it says unable to connect and keeps looking for a port. i know the obd2 is working because the power light on hhh usb to serial port box is on. when i plug it up to the computer only, the power light comes on. yaw find any fixes?
red 99 vr-4 . intrax springs, 3sx dp and test pipe
airtimehocutt is offline   Reply With Quote
