Old 04-21-2009, 07:27 PM   #1 (permalink)
Grrrrrr
Madcat's Avatar
Drives: 02 Montero
Trader Rating: (12)
Madcat is an unknown quantity at this point
Default Help Tuning with 560cc Evo Inj / E manage / 15G's
Hey guys need some help. To be honest this is my first time at attempting to tune. I have always had Adam or anyone else help me. today I put in a set of 560cc Evo Injectors (they have been cleaned and flowed). Ive set my base correction in E manage for 360 > 560cc. Can anyone give me a good starting map? From idle to whatever? For now I have my entire map set to -37 however this is very basic. The car seems to idle a tiny bit rough and the 02's arent cycling. I plan on running 15psi until everything is ironed out. As far as fuel is concerned - I have a hotwired Walbro. Stock FPR. Fuel rail loop on as well. Would appreciate any input I can get ahold of or whatever info everyone needs.
92 Fiji Blue VR-4
Intake, MBC, ATR downpipe, gutted cats, Prosport Boost Gauge, Defi D Gauge Oil Pressure Gauge. whiteface gauges, vac reduction/egr blockoff, Carbon Fiber hood (now deceased), big shiny Y pipe, MSD Wires, Maximal Performance solid mounts, HKS SSQV , Walbro 255, Optima Red Top, Scanmaster 3, IPS Single Shot, Carbotech slotted rotors with SS brake lines, PLX SM AFR Wideband O2, E Manage Blue w/ Ultimate Harness, 560CC Injectors, Fuel Rail Loop, Ported 15G Turbos, Greddy Full Auto Turbo Timer, 99 Lifters
Madcat is offline   Reply With Quote
Old 04-22-2009, 08:26 AM   #2 (permalink)
AWD rules
SLguy's Avatar
Drives: 94 black SLTT & VR4
Trader Rating: (22)
SLguy Level 2SLguy Level 2SLguy Level 2SLguy Level 2SLguy Level 2SLguy Level 2
Default Re: Help Tuning with 560cc Evo Inj / E manage / 15G's
Its been a while since I've last touched my e-manage, but since you've set the base correction, the -37 is unnecessary. Someone else please confirm this though.
As far as the idle goes, richen it up some. I've always used the 4 squares in the top left corner as idle. Anyways, just richen it up until your O2s begin to cycle.
If your using a timing map, start off pulling some timing in the boost areas.
Then just go out with a datalogger and a wideband, try to hit your ideal a/f ratio and pull timing where there is knock and advance timing where there isn't knock.
Black 94 SL Twin Turbo Automatic - 63K miles, < 1K on engine
purchased 3/2001, TT converted 6/2003
8.5:1 Arias Pistons, Pauter Rods, DR Stage 3 heads, 3sx td05 kit, EVOIII 16G's (currently set at 17 psi), PTC high-stall torque converter, shift kit, LSD, FMIC, 550cc injectors, walbro 255lph, 3SX single pass radiator, and supporting mods.
Black 94 VR-4 (The black wasp) - purchased 8/10/2009, 80K miles, R.I.P. 2/19/10
Air Intake, Blitz SBC-iD @ 14 psi, 50 lbs of wasp nests removed
2004 Jeep Grand Cherokee Special Edition - Daily Driver
SLguy is offline   Reply With Quote
Old 04-22-2009, 09:54 AM   #3 (permalink)
Paid Member
DarkHeroKOTRAJ's Avatar
Drives: 1993 3000GT VR4
Trader Rating: (6)
DarkHeroKOTRAJ is an unknown quantity at this point
If you are adjusting with the injector scaling you do not need the -37 (thats what the injector scaling does.) NOTE: You will reach 100% injector duty cycle though at some point over 15psi (or sooner depending on your setup.) NOTE 2: Also do you have the lag times in for the injectors? They should be: 360 0.86 ---- 560 0.82
Are you running speed density or with the MAF? What stage wiring are you running? Have you looked at the E-Mange tuning thread?
David P. - Savannah, GA
1993 3000GT VR4 :: Mods :: Forged Block, APR Head Studs, Stage 3 Heads, Racing Cams, Adjustable Cam gears, TD05 EVO 16G Turbos, 3.5 GM MAF With Translator, Dejon Blow Though & Pre Turbo Pipes, 36x14x3 FMIC, 3inch custom intake, FUELAB Prodigy Fuel Pump and 2x filters line @ -10AN, Fuellab Fuel Pressure Regulator with oohnooo hard lines, 720cc Denso Injectors, Custom Exhaust, Greddy Type-RS BOV, Greddy E-01, Greddy Ultimate, AEM gauges (Fuel & Oil Pressure, A/F, & Water Temp), Fidanza Aluminum Flywheel, SPEC Stage 5+ Clutch, Steel front and mid transfer case upgrade, Transfer Case Bracket, NOS Kit, 220 AMP Alternator, All sensors replaced, EGR block off, Solid engine mounts, Ground wire kit, Iridium IX @ .028, if it's metal its polished or powder coated, and some other stuff
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
DarkHeroKOTRAJ is offline   Reply With Quote
Old 04-22-2009, 12:14 PM   #4 (permalink)
Grrrrrr
Madcat's Avatar
Drives: 02 Montero
Trader Rating: (12)
Yeah I corrected that -37... Slight oversight on my part lol. I am running with the stock MAF. Ive read over most of the E manage thread, still haven't made it through all 50something pages. Only thing I am slightly concerned about is that I have read that a number of people have had problems getting these Evo Injectors to cycle. I went out and added up to 10 and removed up to 20 and nothing really changed. Sits pegged at .96
Old 04-22-2009, 12:40 PM   #5 (permalink)
Paid Member
Trader Rating: (6)
I was running the EVO's for some time (about 1 1/2 years) and it can be done though I am/have been at stage 3 wiring (full control) if your only adjusting the MAF Hz it might be a different situation to get it to work for you. Allot of the idle problems come from the injector lag time, but if your at stage one then it does not matter.
If you want you can upload your setup and I would be glad to take a look at it (also note what software version your running as well.)
Old 05-13-2009, 06:19 AM   #6 (permalink)
sleeper
sleeper3000's Avatar
Drives: 1991 mits vr-4 :)
sleeper3000 is an unknown quantity at this point
for the setup you have, you wouldnt need to go all the way to stage 3, unless you wanted to tune it with the global injector sizing feature,its a nice feature and easy to way to get it driveable to get it to a shop to get it tuned with speed density, but if you do it that way you will run into the 100% injector duty cycle problem, and they explain how to overcome that in the emanage thread. people that go to stage 3 always tend to go speed density.
but if your new to tuning i would start with stage 1 and move up from there once your were understanding it more.
you could wire it to stage 2.5 and use the air flow correction map and tune using method 1 until you get it running good to try speed density, either stage is good for speed density, its just at this stage you cant subtract fuel(other then changing the air flow correction map) and you cant use the global injector sizing feature, but at this stage you wont run into the 100% injector duty cycle problem with your current set up
1991 Mits Vr-4
255lph fuel pump,hot-wire, 3rd gen lifters, stillen downpipe, rear pre-cat, removed all the cats, new ips short block, rebuilt heads, blitz dsbc, Aem wideband, fuel lab fpr, msd wires, ik-27 plugs, Emanage Ultimate, with boost and A/F sensors, 13T's, pro-sport boost gauge
Track time - 14.3 1/4 mile (stock)
Track time with mods = ?? coming soon
sleeper3000 is offline   Reply With Quote
Old 05-14-2009, 02:43 PM   #7 (permalink)
Dear diary...
TurboSinceBirth's Avatar
Drives: 93 VR-4
Trader Rating: (15)
TurboSinceBirth is an unknown quantity at this point
This may be of help to you to make sure it's setup right. EManage Ultimate - 3SI Wiki
TurboSinceBirth is offline   Reply With Quote
Old 05-15-2009, 02:08 AM   #8 (permalink)
I set ATL on fire.
Gray Haze's Avatar
Drives: 3500GT VR4/87 MCSS
Trader Rating: (26)
Gray Haze Level 2Gray Haze Level 2Gray Haze Level 2Gray Haze Level 2
keep in mind guys, hes running emanage blue, not ultimate.
1992 3000GT VR-4 #15 of 24. The ORIGINAL Sandstone Gray '99 Conversion.
Resurection is upon us.
www.3stech.org <= Where the meaningful results of your search went.
Gray Haze is offline   Reply With Quote
