#1 (permalink) | ||
I'm a dude.
A bit of background...The car was finally working great! Trims were perfect, o2s were both cycling nicely. SO I was finally able to put in some bigger injectors and start tuning...
So I have 450s@43psi and maft gen II to tune -20 mainscale. Dual widebands and logging going. The car starts and idles and sits pretty around 100 o2 trim. So I'm happy about that! From reading jeff's site about tuning I just start tuning low load up to about 5 just sitting there at idle. So I give that a crack, once I get past ~900/1000rpm the car kinda stumbles and then once I let go the ecu goes into freak mode no longer cycling. The rear and front widebands are acting very differently. here is the initial throttle blip ![]() So what gives with the rear? ~2k ![]() Then after that the car starts reving up/down and the rear o2 was cycling on the wideband?....urka durk? ![]() Any thoughts guys?
Pm me if any of my pictures are dead. Uncut stealth keys for sale! Various colors!
#3 (permalink) |
Here for the tuna.
That is very strange that one wideband leans out so much more than the other.
You didn't happen to log throttle did you?
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts Nov 2008 ROTM ![]() |
#4 (permalink) |
I'm a dude.
black is rpm red is tps
well I sealed up the injectors and that didn't change anything. It seems as if the rear wideband is more sensitve to changes in afr. Once I riched it up it settled to 14.7. There was one point where I could get the car to idle at 2k with perfect cycling nb, and money widebands. The ecu seems to be going into limp mode pretty quick on me. I pulled the o2s and reset the ecu and tried to tune via wideband. I can get it to 14.7 up to 3k rpm with some pretty heavy rich correction base mainscale -20 1200 +3 1600 +7.5 2200 +7.5 2800 +6 I dunno, it feels like I'm putting in too much fuel but the widebands were all 14.7s in those ranges. Then I plugged the o2s back in, the ecu imediatly didn't like it and limped home. -Antoni |
#8 (permalink) |
New project in the works
I am also leaning towards an injector problem. check your electrical connections and the injectors themselves (sounds like you already verified the install ruleing out a vac leak).
-Josh
mildly modified blue 93 rt/tt-SOLD 3780lbs, pump gas 3/s. 127.08mph-92 octane. I still tune cars! new project, T.B.A |
#10 (permalink) |
I'm a dude.
Alright mystery solved!
looks like my lm1 sensor(rear) went bad. I swapped the sensors and the lc1 throws an error code with the lm1's sensor. Weird that the lm1 didn't throw an error. When I went to the track with the cranked 360s I noticed the rear was reading SUPER rich, like 8s compared to the front at ~11. I made the assumption that it might be bad and was right. I put the 450s back in and just tuned by the good sensor. After a few tries I was able to dial the low rpms to like 3krpm without the ecu limping. Looks like these 450s have different flow characteristics than the "388s" I had in. -Antoni |
