#21 (permalink) | |
Dont f#@k with me I own a
Tunning low throttle is pretty easy really with a logger, just add or remove fuel till you get close to 100% trims. It's getting the hang of the emanage which will be more difficult but once he uses it a bit it will help him in the long run too. Also it doesent have to be perfect, just get it close and the ecu can compensate for the rest.
#22 (permalink) | |
I took the car for a drive and logged the results with the HHH logger. On the graph, it stated 47* @ 4750rpms. This may be a stupid question, and feel free to shoot me down. Can the AF be tuned to different values accross the power band? The reason I ask is, I've been told to tune the car at 11.3 - 11.6, and now your saying at idle/cruise, it should be 14.5
Manj's Wanna-Be GTO
Complete Custom Body Kit and Paint (Viper Red with 3 pearls), 19T-HL with 7* clip, FMIC, Greddy BOV , eManage Blue, Denso 660's, 18" Kosie Sniper Rims, HKS Intake, 3" Downpipe, Testpipe and MagnaFlow Exhaust system, ACT Clutch, Eibach Springs, NGK Plugs and Wires, Autometer boost and Air/Fuel gauges, Supra Fuel Pump, EGR Block Off Plates, Pioneer Deck, 3 Boswick Amps, 2 12" Boswick Subs, JL Front and Mids...... Can't forget the Bat Man floor mats ![]() ![]() |
#23 (permalink) | |
I will be making an appointment with the tuner next week to get the car re-tuned. I'm trying to get a little educated with the whole tuning before I meet the tuner, at least this way I can question him about what he did on my car. |
#25 (permalink) | |
I'll see if I can explain it for you. 14.7:1 is a stoichiometric burn basically it is the best burn for emmisions purposes but once you go into boost this is a dangerous afr and would completly destroy your engine. So the ecu from the factory will richen the mixture to keep your car from puking pistons when you go into boost. When boosting 11.0-11.5 is a good tune, anything richer will be too much fuel. Now how do you know when to tune for one afr or the other you may ask? Easy, everyday driving is 14.7:1 at all rpm's in all gears (it does change slighly as you go into higher rpm's but I wont get into that, you could refer to the table above if you want). The only time you want 11.0-11.5 is when you hammer on the gas and go into full boost. Now getting back to your current situation you do not need to worry about tunning for 11.0-11.5 since your not toughing anything to do with boost (please dont touch it ) since it's fine. All you need to do is tune everyday driving which is the 14.7:1. Now since you do not have the means of seeing the exact afr you can completly forget about any numbers I have spoken about as it will have no relation to the way you tune.All you will do is remove fuel on the emanage on the low load/rpm tables to get your trims around 100%(approx 14.7:1), thats all you need to worry about. If you still dont really understand the afr concept thats fine as you dont really need to know it to do what you need to do but I would highly recommend you read up on it more before you try to change any tunning on your own (without someone guiding you). Last edited by Overboosted : 07-05-2008 at 10:54 AM. |
#26 (permalink) |
I showed my log files to the tuner and he said he'll redo the tune up.
He doesn't have any way to data log stealth's/3000GT's as he never works on them. When he saw the fuel trims, he knew something was wrong. The car will be ready in a few weeks after my vacation to sunny south in Florida ![]() thanks for all the help, I'll post my dyno chart when done |
#28 (permalink) |
I had a chance to go back to the tuner.
We sat down together with the car on the dyno and he educated me on how to tune. Unfortunetly, the tune he did was the best he could do cause he said my fuel trim can not be adjusted as my 02's are reading way to high. They are always reading at 0.8 - 0.9 which is super rich and dumps so much fuel When I get new 02 sensors, then my tune will be better. Now I gotta order some 02's. |
#29 (permalink) |
What? This is for a cruising tune right? .8 - .9 sounds like the narrowband reading under full boost/open loop. The stock o2 sensor should be cycling real fast back and forth never staying in one spot if your looking at the voltage. If your looking at the datalogger than the o2 trims should be hovering around 100%.
#30 (permalink) | |
Forest Gump
Even some respectede tuners are trying to hit 10.5-11:1 (.96 narrowband approx) across the board. No clue why as the engine doesn't need that much fuel at low revs.
![]() Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts, EK2 ExoCage Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcapsm Scanmaster 3 Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear |
