Old 07-29-2008, 10:56 PM   #1 (permalink)
Drives: one of 3 vr4's
rlataille Level 1rlataille Level 1
Default Emu Timming Issue Lets Fix It
I have messed with my EMU and I believe that if some one with a data logger plays with the cam angle offset angle (found under the car preferences) they can figure out the magic # that will get the emanage to display actual timing. Will some one please do this ASAP. I have my fingers crossed
IF YOU NEED ANY WORK DONE ON YOUR 3S GIVE ME A CALL AT 540-454-0925
PARTS for SALE
EMANAGE ULTIMATE Complete setup
3.15L built short block
denso 660cc injectors
MSD DIS-4- http://cgi.ebay.com/ebaymotors/ws/eB...m=130270776765
6G74 DOHC JDM PARTS Parts NEEDED
Bracket power steering pump mounting
Bracket Alternator (big Bracket)
Pulley power steering belt adj
Cover Timing belt Forward
Cover Timing belt Lower
Cover Timing belt rearward
Thermostat housing
400HP 91 dsm sold
1991 VR-4 PEARL WHITE (Galatea)
WITH MODS
Pics of the building:
http://s181.photobucket.com/albums/x127/vr440/
1998 base 3000gt sold
1991 red vr4 sold
1991 orange/black 49,000 original miles sold
1992 red sl being parted out gone
1990 300zx NA SOLD
1994 VR4 REBUILT ENGINE AND 15G's SOLD sak1782
1992 VR4 TD05 Red with black interior sold
1992 silver SL sold
1992 STEALTH TT in the works
1991 300ZX TT
rlataille is offline   Reply With Quote
Old 07-30-2008, 11:08 AM   #2 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
Trader Rating: (162)
BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7
Default Re: Emu Timming Issue Lets Fix It
Run v1.14 if timing is that important to you.
BlackStealth is offline   Reply With Quote
Old 07-31-2008, 06:39 AM   #3 (permalink)
just some guy.
Racer_X's Avatar
Drives: 94 Stealth Turbo
Trader Rating: (9)
Racer_X Level 4Racer_X Level 4Racer_X Level 4Racer_X Level 4Racer_X Level 4
It's 120 degrees off when it freaks out, so try +120, if that is still way wrong, try -120. there will be a +/- 3 degree difference between cars. This is where you need a timign light. it's pretty easy to tell what it is supposed to be because when it freaks out, you can typically see the before and after effect.
I already posted this information on the thread you made a few days ago. did it not work?????????????
Pretty good for 2 shot turbos and a boost leak
Racer_X is offline   Reply With Quote
Old 07-31-2008, 06:52 AM   #4 (permalink)
Master Of Disaster
Gray Haze's Avatar
Drives: 3500GT VR4/87 MCSS
Trader Rating: (26)
Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7Gray Haze Level 7
adjustments aren't allowed beyond 60 deg in either a positive or negative adjustment.
1992 3000GT VR-4 #15 of 24. The ORIGINAL Sandstone Gray '99 Conversion.
Stroker + Heads + AEM + IPS Evo3 Kit + other junk...
www.3stech.org - Now with 100% less invite codes! Free Registration!
Gray Haze is offline   Reply With Quote
Old 08-07-2008, 03:24 PM   #5 (permalink)
Elina75's Avatar
Drives: 3000GT VR4 1993
Elina75 is an unknown quantity at this point
Anyone tested if the latest v2.20 fixed that?
Elina75 is offline   Reply With Quote
Old 08-07-2008, 04:20 PM   #6 (permalink)
Drives: 93 RT/TT
http://translate.google.com/translate?u=http%3A%2F%2Fwww.trust-power.com%2Fsystem%2Fview%2Findex.php%3Fno%3D03%26pub%3D1&langpair=ja|en&hl=en&ie=UTF-8
Our ignition type is MT_1 and is not mentioned so I'd say it has not been fixed.
Old 08-07-2008, 05:11 PM   #7 (permalink)
Drives: 93 RT/TT
V2.20 english is missing an entry that comes up with an error. Here's the fix, and some spelling mistakes corrected by yours truly.
Old 08-08-2008, 01:49 AM   #8 (permalink)
Elina75's Avatar
Yeah, it's not
I really don't buy their explanation that they don't have a GTO or the engine is broken, it's clearly a bug in their software and they have fixed it for several other engine types, hard to image where would they need a car to fix the bug for MT_1 as well I'm sure there are people who would beta-test or whatever if they fixed it. If they really don't have any sw-simulator in-house.
Old 08-08-2008, 07:41 AM   #9 (permalink)
just some guy.
Racer_X's Avatar
Trader Rating: (9)
I buy that excuse. 3000GT/GTO's are RAAAAARRRRRE in Japan. It's an old, BIG car that gets crappy gas mileage that nobody wants and is only modded by "a few" specialized shops (kinda like America, but with more expensive gas and smaller streets). I have been over there a couple of times and I didnt' see a single one on the road at ANY time. the only ones I saw "at all" last time I went were in Pit Road M's booth at the Tokyo Auto salon (GTO shop #1) and at Kaze Aerocraft's booth (GTO Shop #2). that's it . None of the evo guys are crying over this issue, so they can't really "do" anything about it. the issue will probably not get resolved .
Old 08-08-2008, 11:19 AM   #10 (permalink)
Elina75's Avatar
My point was where do they need the car at all? I don't think they will fix the problem by stripping a GTO and looking what's under the hood or carpets. They can already read the ingition signal, it's just that for some reason their software goes mad when certain conditions are met (I just neet to rev over 4000 rpm once and it's there). And the same bug has been already fixed with other engine types, so they probably even know what the problem is, just looks like they are more interested addin new features and support for new devices (to sell more), than spend time fixing even years old bugs.
Wouldn't have gone with the emu if knew how crappy their support is and how much they care about fixing so obvious problems.
