Old 07-27-2008, 09:51 PM   #1 (permalink)
Drives: one of 3 vr4's
rlataille Level 1rlataille Level 1
Default EMU timming issue
so my emu is showing like -110 degees alot of the for ignition alot of the time What is wrong because that is obviously not right. This happens during decell/accel/ idle.....
IF YOU NEED ANY WORK DONE ON YOUR 3S GIVE ME A CALL AT 540-454-0925
PARTS for SALE
EMANAGE ULTIMATE Complete setup
3.15L built short block
denso 660cc injectors
MSD DIS-4- http://cgi.ebay.com/ebaymotors/ws/eB...m=130270776765
6G74 DOHC JDM PARTS Parts NEEDED
Bracket power steering pump mounting
Bracket Alternator (big Bracket)
Pulley power steering belt adj
Cover Timing belt Forward
Cover Timing belt Lower
Cover Timing belt rearward
Thermostat housing
400HP 91 dsm sold
1991 VR-4 PEARL WHITE (Galatea)
WITH MODS
Pics of the building:
http://s181.photobucket.com/albums/x127/vr440/
1998 base 3000gt sold
1991 red vr4 sold
1991 orange/black 49,000 original miles sold
1992 red sl being parted out gone
1990 300zx NA SOLD
1994 VR4 REBUILT ENGINE AND 15G's SOLD sak1782
1992 VR4 TD05 Red with black interior sold
1992 silver SL sold
1992 STEALTH TT in the works
1991 300ZX TT
rlataille is offline   Reply With Quote
Old 07-28-2008, 06:23 AM   #2 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
Trader Rating: (162)
BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7
Default Re: EMU timming issue
V1.14 firmware/software the timing number reports correctly. After v2.00+ there's a bug in the software which reports the timing number incorrectly for our cars. A user on here has notified Greddy with this bug so they are now aware of it, but Greddy is having a hard time locating a GTO vehicle in Japan. Supposedly they found one but the engine is broken and needs to be repaired first.
A while back I looked into the timing problem and noticed that if I added a fixed number it would report the correct timing number. I forget what the number was as I don't even look at timing on the emanage datalogs anymore. I prefer to look at knock instead.
BlackStealth is offline   Reply With Quote
Old 07-28-2008, 09:32 AM   #3 (permalink)
where would i enter this fixed #. I also seem to have alot of noise in my knock what kind of values would represent true knock? is there some where i can input my noise value so that It will not show up on the log?
Old 07-28-2008, 09:36 AM   #4 (permalink)
is it the offset angle for the crank angle sensor?
Old 07-28-2008, 11:03 AM   #5 (permalink)
Drives: 93 RT/TT
I think the number was something like 120, but can't recall. You add the number in your head. I measure knocksum and not knock voltage on my OBDI datalogger.
Old 07-28-2008, 01:00 PM   #6 (permalink)
just some guy.
Racer_X's Avatar
Drives: 94 Stealth Turbo
Trader Rating: (9)
Racer_X Level 4Racer_X Level 4Racer_X Level 4Racer_X Level 4Racer_X Level 4
yeah, it drops 120 degrees on some 6 cyl cars and 180 degrees on some 4 cyl cars. adding that number to the crank ofset angle should be a big help. I wish I had thought of that earlier :-P. I have sent a few e-mails to Trust Japan and they still don' thave a test car and don't know when they will . Oh well. Looks like our cars are becoming less JDM Tyte by the minute
Pretty good for 2 shot turbos and a boost leak
Racer_X is offline   Reply With Quote
