Old 05-06-2008, 06:34 PM   #11 (permalink)
rock on, yeah rock on
spfan's Avatar
Drives: 4 x 22,000 lbs jets
spfan is an unknown quantity at this point
Default Re: emanage ultimate software help
cool, i'll go ahead and do that. do i need to update the firmware too? i'm just hesitant because i finally got it working right, don't want to mess it up now.
and gray haze's speed density map...where can i find it? and what kind of setup is it geared toward? i hadn't heard of it before and i may very well need it before too long.
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53
1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info currently getting rebuilt at IPS Motorsports
2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD.
13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack)
13.09@105.08 (1.80 60', same conditions as above)
305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time
Beyond BPU: (meaning upgraded turbos/fuel/etc)Mods at that time
12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms)
12.41@115.10(ditto)
spfan is offline   Reply With Quote
Old 05-07-2008, 04:36 AM   #12 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
Trader Rating: (146)
BlackStealth is an unknown quantity at this point
v2.16 software will force you to upgrade the firmware to 2.16 the first time you connect your emanage, flash takes about 3 minutes to do.
-= Ultimate Emanage Tuning Thread =-
BlackStealth is offline   Reply With Quote
