Emanage + GM Boost Solenoid = EBC for $10.32 - 3000GT/Stealth International Message Center
Old 11-07-2005, 04:46 PM   #1 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
BlackStealth Level 1BlackStealth Level 1
Feedback Score: 219 reviews
Default Emanage + GM Boost Solenoid = EBC for $10.32
Both the blue and ultimate series emanage offers subinjector control for the purpose of adding an additional fuel injector. Majority of us do not use this feature, and in this article I'll use it for a different purpose. If you already have the greddy boost pressure sensor then you can use the greddy subinjector map as an electronic boost controller map. Blue emanage owners may have to purchase additional wiring.
Parts Needed:
- GM Boost Solenoid (part # 1997152) $10.32 at GM Parts Direct: Your direct source for Genuine GM Parts
- Solenoid Connector (part # 15305891 $18.79 at GM Parts Direct: Your direct source for Genuine GM Parts
I picked up a couple GM solenoid connectors at a local pick and pull junk yard for free. Take your boost solenoid with you to the junk yard and visit some GM cars. Some GM cars use this connector as their intake temperature sensor connector or coolant temperature sensor connector. I don't understand how they could charge so much for a simple connector. And no, I didn't make note as to which vehicles I got them off of.
Electrical Installation:
Since the GM Boost solenoid is non-polarized, it doesn't matter which end of the wire gets ground and which wire gets 12 volts. My wire had one red lead and one blue lead, so I used the red lead for 12 volts, and the blue lead for the emanage ground. If you actually purchased the GM solenoid connector, you'll have two white wires as leads. Wire up the GM boost solenoid as indicated in my diagram.
Vacuum hose installation:
The GM Boost solenoid has three vacuum nipples with one nipple attached to a foam filter. Leave that filter on. The adjacent nipple to the foam should be connected to your wastegates. The remaining nipple should be connected to your Y-pipe, as illustrated in my diagram. Don't reverse the solenoid.
My GM Boost solenoid fit well near the factory boost solenoid location.
Usage:
100% duty cycle means maximum boost. 0% duty cycle means lowest boost possible (wastegate pressure). The GM Boost solenoid with no power, by default is normally open. This is a good thing, in the event of a failure you will run only wastegate pressure (low boost). You could also use other high speed solenoids in place of the GM Boost solenoid. Be sure to select one that is normally open for safety reasons.
Simulated MBC:
If you're still using a MBC, you can simulate it pretty well with this setup. Just enter the same duty cycle number everywhere on the map. And now you've got a simulated MBC. You'll have no idea how much boost you'll make just like a real MBC. You have to drive your car and check out the results. If you didn't make enough boost, you would turn your MBC knob to make the air passage smaller. Similarly on the GM Boost solenoid, you need to increase the duty cycle to reduce the air passage. This process involves a lot of trial and error until you've reached your goal. What sucks about a MBC is you gotta pop your hood open, undo your seat belt, climb out of the car, adjust the MBC knob, close the hood, climb into the car, put your seat belt back on and make another run each time. With this simulated MBC, you just reach over to your notebook and change the duty cycle. Enjoy your new simulated MBC.
Spoolup:
The previous example sacrifices spoolup a little bit. Suppose you want a target boost of 17psi. Ideally, you would want the solenoid to be fully closed (100% duty cycle) anything below 17psi for maximum spoolup. But in reality, this control system cannot react that quickly and would overshoot easily. What you should do is keep the wastegate 100% closed a few psi before reaching your target. In my example, I chose 11 psi, but you can experiment to see what works best for you.
Noise:
The GM Boost solenoid is rather noisy especially when you're at idle or cruising around and at WOT you probably won't even hear it over the engine noise. There's no point in over working your solenoid when you're below wastegate pressure. Since the TD04 wastegates open around 6 psi, you could theoretically keep the solenoid turned off during this time. But wastegates don't swing open exactly at 6 psi either, they slowly creep open as they approach closer to their target psi. Anything below 4psi and under I keep the solenoid turn off (0% duty cycle). Having 0% duty cycle here won't hurt spoolup. As you can see in my map, at 5 psi I fully close the solenoid before reaching the wastegate critical pressure of 6psi. I don't want the wastegates to prematurely open as we approach it.
Duty cycle:
As you can see in my map, after 5000 rpms I had to tweak the duty cycle. If your boost falls off, increase the duty cycle. If your boost overshoots, decrease the duty cycle.
Safety:
In my map, anything above 18 psi has 0% duty cycle (wastegate pressure). So if you accidentally overshoot, you'll go back to wastegate pressure. This is something your everyday MBC can't do. Protect your engine from overboost.
Adjust your boost:
Now suppose you want to increase your boost, ie. from 17 to 18 psi. Just copy all the cells from 12psi through 17psi and copy them into the new location of 13psi through 18 psi. And copy 100% duty cycle on the 12 psi row to keep the wastegate closed for maximum spoolup. Eventually when you increase the psi a lot more, you'll have to retweak the duty cycle again.
Other solenoids:
For fun, I tried the stock boost solenoid. I could only get about 12 psi, and the boost fell off. Not worth pursuing.
Conclusion:
Well, there you have it, an affordable electronic boost controller that can be made roughly for the same price as a MBC. My old AEM EMS uses this same strategy to control the GM Boost solenoid, but also offered the option of using two feedback circuits. But one thing I do like better on the ultimate is the ability to change the PSI scale and RPM scale independently from the fuel map scale. I couldn't get this fine PSI increments on the AEM EMS without screwing up my fuel map scale.
BlackStealth is offline   Reply With Quote
Old 11-08-2005, 09:41 PM   #2 (permalink)
Snakes on a Helicopter!
intruder1_92TT's Avatar
Drives: While Posting on 3si
intruder1_92TT Level 1intruder1_92TT Level 1intruder1_92TT Level 1
Feedback Score: 8 reviews
Default Re: Emanage + GM Boost Solenoid = EBC for $10.32
Kick ass job!!! I'll have to try this out
1992 Dodge Stealth RT/TT Pearl White and black /w blue pearl. Mods: Lightweight's MBC; K&N cone filter ; GReddy E-manage + all harnesses and press. snsr; DSM "Blacktop" 450's; Walbro 255; 1G DSM BOV (Recirculated); Polished Y Pipe; Slotted Rotors all around; Hawk HPS front pads and KVR CF rear pads; Enkei 18x8's with Nitto NT555 245/40's
intruder1_92TT is offline   Reply With Quote
Old 12-29-2005, 11:00 PM   #3 (permalink)
Slowed by traffic
enigma9o7's Avatar
Drives: 95 VR-4 Spyder
enigma9o7 is an unknown quantity at this point
Feedback Score: 21 reviews
Nice. See if you can get this hosted somewhere and linked on stealth316, this is an excellent writeup and I don't wanna loose it
1995 Black VR-4 Spyder - Daily Driver, purchased March 2005. PST Carbon Fiber Driveshaft, Southbend TZ Clutch, UR Flywheel, K&N FIPK, DNP Y-Pipe, Stillen Downpipe, Custom Single Shot Exhaust, Tein S-Tech front/H-Tech rear, Carbotech Slotted Rotors, Ohio Spyderman short shifter, Mobo leather shift boot, manual leather seats from an SL.
_________________________
1993 Panama Green Pearl Mitsubishi 3000GT VR4 - Daily Driver July 2002 - April 2006 & May 2007. Totaled by drunk driver who hit it while parked on a 25mph street May 20 2007 10:30pm.
STOP/GO: Southbend DXD 6-puck, K&N FIPK, ProBoost MBC, M-Spec Vacuum Reduction Kit, Stillen Downpipe. Powerslot Front Rotors w/Hawk HPS Pads.
SUSPENSION/DRIVETRAIN: Intrax Springs, Bilstien Rear Shocks, KYB GR2 Front Struts, 5Zigen FN01RC 18x8.5 +30 & 18x9.5 +35 Wheels with Nitto Extreme Performance 245/40/18 & 285/35/18 Tires (summer), 245/45/17 Bridgestone Blizzak WS50 on Spyder Chromies (winter), PST CFDS, UR Aluminum Flywheel.
LOOKS: 5% Tint, Snakeeyes, Niteshades, Mobo Leathers Lower Door Inserts, 3KGT Concepts Aluminum Defroster Vents, Speedhut EL-Glo Gauge Faces
AUDIO/VISUAL: JBL GTO220s, Pioneer TS-A1646 2-ways & Stock 6x9s all powered by Phoenix Gold Octane-R 5.1 Dolby Digital Amp, Infinity 1032W 10" Fiberglass Mounted Subs powered by Rockford Fosgate 501bd Amplifer, 7" Motorized LCD DVD/TV/FM/MP3 Deck, SWIX Steering Wheel Control Interface
COUNTERMEASURES: Blinder M10 Twin Laser Jammer, Scorpion Ultimate KA Radar Jammer, Radio Shack PRO-2067 Mobile Scanner Radio
SECURITY/CONVENIENCE: Compustar 2-Way Spread Spectrum Alarm/Autostart/Turbo Timer/Keyless Entry.
1992 Black Dodge Stealth R/T Turbo - off the road with unsolvable problem.
1991 Red JDM Mitsubishi GTO SR - Daily Driver Dec 2001 - May 2002. SOLD
RHD, AWD/AWS, Aero, Auto, NA
enigma9o7 is offline   Reply With Quote
Old 08-04-2007, 06:41 PM   #4 (permalink)
Registered User
Drives: 1993 RT/TT
KnTStealth93 is an unknown quantity at this point
Feedback Score: 6 reviews
anyone know what harness is needed to do this with a blue emanage?
KnTStealth93 is offline   Reply With Quote
Old 12-31-2007, 10:53 AM   #5 (permalink)
rlataille's Avatar
Drives: VR4, GSXR 1000, A4
rlataille is an unknown quantity at this point
can some one running this post a map?
so the EMU side is the ground not the power correct?
how do you setup the emu to output to the subinjector?
Slide Show of my car 2006-11
If you need work done on your 3S I can help, I am located in the Northern Virginia call me at 540-454-0925 - Robert
rlataille is offline   Reply With Quote
Old 07-12-2008, 08:46 PM   #6 (permalink)
Drives: 93 RT/TT
Update: Fixed broken image links.
Old 07-12-2008, 10:05 PM   #7 (permalink)
Banned
Drives: 92 15G3KGTVR4
Cool Name Here Almost GoneCool Name Here Almost GoneCool Name Here Almost GoneCool Name Here Almost GoneCool Name Here Almost GoneCool Name Here Almost GoneCool Name Here Almost GoneCool Name Here Almost GoneCool Name Here Almost GoneCool Name Here Almost GoneCool Name Here Almost Gone
Feedback Score: 5 reviews
Damn it bro, I DO need to get you down here to Florida to tune my shit, lol. Make sure your passport is in order, lol
BTW, how are you tuning your GUEM? Off a laptop or car-pc? I am now trying to find a unit that I can keep in the car so I can watch and have it tuned in real time/on the fly. Looking into a PC tablet (a laptop with out the key board).
I was even thinking about getting the new Nokia 810 Nokia - Nokia N810 - Compare Phones - Find products
Edit: FYI, the Nokia 810 is NOT a cell phone, it is just s UMPC. Don't know why it says phone.
Cool Name Here is offline   Reply With Quote
Old 07-12-2008, 10:31 PM   #8 (permalink)
Drives: 93 RT/TT
I use both a notebook and carpc, just depends what I feel like, but lately I've been using a carpc.
Old 07-12-2008, 11:52 PM   #9 (permalink)
SOCOM Racing League
James92TSi's Avatar
Drives: #388 Red
James92TSi Level 1James92TSi Level 1
Feedback Score: 17 reviews
Thanks so much for fixing the pics!
'91 3000GT VR-4 Silly car, get down from there. You're not a plane. You don't even have wings.
'03 G35 Sport Coupe Retains transmission and full warranty, even with VDC off!
Originally Posted by Kenneth Ellis
In case you haven't noticed, it's an internal combustion engine; it runs on air, fuel, and a spark being delivered every couple hundredths of a second. It doesn't run on rays of sunshine being blown out your ass with ample amounts of pixie dust and hope.
James92TSi is offline   Reply With Quote
Old 07-13-2008, 12:00 AM   #10 (permalink)
LeRoyDL's Avatar
Drives: 1992 R/T TT Conv.
LeRoyDL is an unknown quantity at this point
Feedback Score: 52 reviews
awesome thread, never saw this in the past. already have a ebc but damn.. this is neat.
1992 Stealth R/T
Drive Train/Performance:
Aem FPR (Rob's adapter), DR650r's, Borla Cat-Back, Dejon Intake / Blow Through Setup, GM Maf / Maf-T, Greddy E-Manage (Blue), Greddy E-01 Boost controller, Greddy Type RS BOV,
Maximal Performance Solid Motor Mounts, MSD Ignition Wires, Optima Yellow Top Battery, Spec Stage 3 6 puck Clutch, Walbro Fuel Pump, Wiseco Pistons.
Exterior/Appearance:
1999 3000GT Front Bumper, Headlamps and Turn Signals, Second Generation Stealth Hood, Side Skirts/Door Caps, Rear Bumper and OEM 96 Wing.
Interior:
Cianci Triple 60mm Gauge Pod (matching passenger side replacement), Charcoal roof/pillar conversion, Greddy Counter Weight Shift Knob,
Greddy Silver 60mm P/H/W Gauges (center replacement and gauge pod), LC-1 Wide Band, M515 PDA/MMCD Data Logger,
Seattle Roller Bearing Short Throw Shifter.
Other
List getting to big, really to much shit to list.
Suspension/Wheels:
Black Racing Pro N1 17x9 Wheels, Cusco Front and Rear Strut Bars, Cusco Front Strut mounts, Ground Control Coil Overs (Stock ECS Struts), Stealth TT Brake Upgrade.
Soon To Come:
A drivable car!!!!
To Do:
Finish building/Install motor, Install Water/Meth Injection, Tune Properly, Paint and Install AWD Conversion parts (after motor break in/tuned).
LeRoyDL is offline   Reply With Quote
