LinkBack (2) Thread Tools
Old 08-26-2005, 12:44 AM   #11 (permalink)
starquest 2875's Avatar
Drives: Twin EVO III
starquest 2875 is an unknown quantity at this point
Default Re: Detonation vs. Pre-Ignition
that was a long, but very good information.
starquest 2875 is offline   Reply With Quote
Old 08-26-2005, 01:27 PM   #12 (permalink)
The Codebringer
Gatecrasher's Avatar
Drives: 02 SVT Focus
Trader Rating: (7)
Gatecrasher Level 1Gatecrasher Level 1Gatecrasher Level 1
This article ought to be required reading for anyone looking to do their own tuning.
Thanks for posting it. This will go in my reference library.
-= sig goes here =-
Gatecrasher is offline   Reply With Quote
Old 09-21-2005, 01:01 PM   #13 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 1Kibwe Walker Level 1
Thanks for the Advanced section. Great read.
Red 93 RT/tt project car
Mods: stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, dsm SMIC's, Tein S springs, pte 580 inj's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
94 vr4: RIP 4/16/09
Kibwe Walker is online now   Reply With Quote
Old 09-21-2005, 01:02 PM   #14 (permalink)
Drives: 93 RT/tt
Someone should sticky this.
Old 09-21-2005, 02:21 PM   #15 (permalink)
I miss my boost.
Synchro's Avatar
Drives: '01 S2000
Trader Rating: (10)
Synchro is an unknown quantity at this point
Excellent read. Cleared quite a few things up for me. This should be required reading for *everybody*, not just tuners.
Synchro is offline   Reply With Quote
Old 09-21-2005, 11:48 PM   #16 (permalink)
Trader Rating: (8)
TiM_natalie3kGT is an unknown quantity at this point
yes it was a very good article
Sticky
95 VR-4
TiM_natalie3kGT is offline   Reply With Quote
Old 09-22-2005, 10:56 AM   #17 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: 2005 Toyota Prius
Trader Rating: (20)
mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3mjannusch Level 3
Sticking it...
-Matt
'95 3000GT Spyder VR4 (11.838@117.56)
'93 3000GT VR4 (Drag car project)
mjannusch is offline   Reply With Quote
Old 10-03-2005, 01:25 PM   #18 (permalink)
Vr4 put me in debt
Jimmy Nuetron's Avatar
Drives: it like its broken
Jimmy Nuetron is an unknown quantity at this point
its amazing, if i read a text book at midnight, it doesnt stick, but i read this through sometime around midnight, and i think i remembered most of it, and it explains what happened to my dads snowmobile when he was runnin stock jets and our own homebrew ram air, there was aluminum all over the spark plugs..hmmm...
thanks for puttin it out there
jim
If I spelled Neutron right, would that be copy right infringement?
sold out
Jimmy Nuetron is offline   Reply With Quote
Old 10-03-2005, 02:22 PM   #19 (permalink)
mjannusch's Avatar
Trader Rating: (20)
Originally Posted by Jimmy Nuetron
...it explains what happened to my dads snowmobile when he was runnin stock jets and our own homebrew ram air, there was aluminum all over the spark plugs..hmmm...
You may have hooked up your ram air and forgot to pressurize the float bowls from the airbox... Without doing that, the ram air pressure will tend to hold the fuel down in the bowl and not allow as much up through the jet/needle. Going a size or two higher on the main jet is probably a good idea anyways, at least until you determine that it runs too rich.
Old 10-25-2005, 11:03 AM   #20 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
Originally Posted by klamathpro
So according to the above info, detonation most likely occurs in places other than the dead center of the chamber, thus running colder plugs doesn't help that much for true detonation and definitely doesn't draw or pull away heat from the chamber or anything silly like that. Colder plugs prevent pre-ignition which occurs 160 - 180 BTDC and possibly detonation induced pre-ignition because it minimizes the plug from becoming a heat spot. This is apparent from this thread showing detonation occurring away from the center.
Your summation is incorrect. One of the main jobs of a sparkplug aside from igniting the mixture is HEAT REMOVAL from the chamber. It is this HEAT (along with pressure) in the chamber that causes detonation. The colder the plug the more heat (and faster) the plug can pull out of the chamber and move it to the cooling system for removal. This chamber cooling is what colder plugs are all about. And this is why colder plugs lower chances of detonation.
Colder plugs also pull heat off thier tip faster which does help pre ignition as well.
Key Definitions
Detonation
Detonation is the spontaneous combustion of the end-gas (remaining fuel/air mixture) in the chamber. It always occurs after normal combustion is initiated by the spark plug. The initial combustion at the spark plug is followed by a normal combustion burn. For some reason, likely heat and pressure, the end gas in the chamber spontaneously combusts. The key point here is that detonation occurs after you have initiated the normal combustion with the spark plug.
Detonation
Unburned end gas, under increasing pressure and heat (from the normal progressive burning process and hot combustion chamber metals) spontaneously combusts, ignited solely by the intense heat and pressure. The remaining fuel in the end gas simply lacks sufficient octane rating to withstand this combination of heat and pressure.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-770AWHP 747AWTQ 30psi E100 Daily Driver 10.57@136mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f103/detonation-vs-pre-ignition-281822/
Posted By For Type Date
More detonation questions. PICTURES - Speed Talk This thread Refback 04-16-2008 10:22 PM
pre-ignition / detonation(post ignition) - Speed Talk This thread Refback 04-13-2008 12:47 AM
