#1 (permalink) |
elvis lives
got the all to familiar cel light today,, only this time it didnt go away. upon further tests, the leds in the maf-t dont come on when the key is turned on. it is getting good power on the pink wire in the main harness. and good ground. there is no power to the pink wire in the maf harness.
should i look to buy a replacement or is there a fix?? thanks guys..
91 rt/tt, with lots and lots of mods done up poppa smurf style!!
#2 (permalink) | |
Resident mad scientist
You can do a quick fix, splice the 2 pink wires together (and look for the pinched spot on the pink wire.) Or you can send the unit in to Full Throttle Speed for repair. Bob
Need a datalogger? Check out the Scanmaster 3
PM me about ECU mods for 8000+ RPM rev limits !!!!!!!! Stock = 7300 RPM Stage 1 = 8060 RPM Stage 2 = 8200 RPM Stage 3 = 8400 RPM Stage 4 = 8800 RPM (By request only) ![]() 1991 Stealth RT/TT, Grooms Shortblock, 13G's, Translator Pro, www.maftpro.com My Stealth is for sale, 65000 miles, runs perfectly. $7,500 ![]() |
