Old 02-26-2008, 09:50 PM   #1 (permalink)
Boost Happy
Black_Sunshine's Avatar
Drives: a japanese dodge
Trader Rating: (70)
Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7
Default AEM UEGO vs. Innovate LC-1, which is better?
i'm planning on buying a wideband O2 sensor kit next month and i was wondering if one or the other was better? i would like to connect the wideband to my emanage ultimate and it looks like the LC-1 has an extra wire that can do just that without extra splicing. They both cost about the same, the LC-1 being slightly cheaper. i see a lot of people using the aem uego and was wondering if either one is better.
one thing about the LC-1 tho, in the pix i've seen, it has 1 jack for the analog signal while the emanage requires 2 wires (+ and -) to be wired. if i cut the jacket off the LC-1 jack, are there 2 wires i can connect to for the emanage?
Thanks,
Tri
Black_Sunshine is offline   Reply With Quote
Old 02-27-2008, 05:54 AM   #2 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
Trader Rating: (162)
BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7
Default Re: AEM UEGO vs. Innovate LC-1, which is better?
I initially installed my WB02 into emanage using only 1 wire (signal). Months later I attached the ground wire and it made no difference, so you can get away with just a 1 wire install on emanage.
BlackStealth is offline   Reply With Quote
Old 02-27-2008, 08:40 AM   #3 (permalink)
just some guy.
Racer_X's Avatar
Drives: 94 Stealth Turbo
Trader Rating: (9)
Racer_X Level 4Racer_X Level 4Racer_X Level 4Racer_X Level 4Racer_X Level 4
AEM in my experience is MUCH more reliable. I can't remember a situation in which I tuned a car with a 100% properly working LM1.......ever.
Pretty good for 2 shot turbos and a boost leak
Racer_X is offline   Reply With Quote
Old 02-27-2008, 09:34 AM   #4 (permalink)
Boost Happy
Trader Rating: (70)
yikes! question for you guys: on the AEM, would it mess up the signal if i tapped off the output wire and ran it to my emanage and the gauge display?
Old 02-27-2008, 12:38 PM   #5 (permalink)
just some guy.
Racer_X's Avatar
Trader Rating: (9)
The AEM wideband gauge has an output wire specificlly for sending the 0-5V signal to other electronics.
Old 02-27-2008, 03:17 PM   #6 (permalink)
Boost Happy
Trader Rating: (70)
awesome. looks like i'll be getting the aem. thanks for your help!
Old 02-27-2008, 08:24 PM   #7 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
markoverclock is an unknown quantity at this point
odd bcause i use the lm1 and never had a problem with it. in fact i have 2 of them and love them also used 3 lc-1 with no problems what so ever (other than one i let the connector full soaked in water because it was behind the tire in the middle of winter.) oopppss.
but they warrantied it when i didnt buy it from them and without a receipt even after i cut it open to see if i can fix it.
innovate all the way.
markoverclock is offline   Reply With Quote
Old 03-04-2008, 10:45 AM   #8 (permalink)
Boost Happy
Trader Rating: (70)
Originally Posted by BlackStealth View Post
Follow Tip #6 for setting up the software too. Keep in mind, the AEM wideband is not linear, so the raw numbers you get will have to be adjusted with a conversion chart for a proper AFR. I'd suggest selling the AEM and go for the linear innovative LC1 since they go for around $189.
so the LC1 would be easier to work with?
Old 03-04-2008, 02:56 PM   #9 (permalink)
Drives: 93 RT/TT
That comment was made when the old AEM WB units were not linear. I would just grab an LC1 and call it a day.
Old 03-04-2008, 03:34 PM   #10 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
ive seen more than a few LM1s and LC1s fail withen a few thousand miles and no race gas or oil.
im more than happy with my AEM
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
95 montero SR. factory rear locker. 3.5 DOHC
91vr4n00maxima is offline   Reply With Quote
