#11 (permalink) |
Nuclear Nerd
IPW? right now that acronym is escaping me....so is there a calculation that i need to do with those parameters...as you might have guessed im just starting to get into this understanding how ECU's control the car stuff,
Mod. list Stillen down pipe w/gutted rear pre-cat. Greddy Profer E-01 on the way. HKS cosmo fuel pump w/ hotwire. Matrix open element air filter. NGK 8MM plug wires Carbotech slotted rotors. Maximal Tcase bracket. more to come....EVO 560's and 15G's and an SAFC-2??? |
#12 (permalink) | |
Here for the tuna.
IPW is injector pulse width, in milliseconds. Essentially how long the injector is firing for. So to find your true IDC, (IPW*RPM)/1200 = IDC. ![]()
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts Nov 2008 ROTM ![]() |
#13 (permalink) |
Nuclear Nerd
beautiful, this whole tuning thing is a bit overwhelming, i am finally to the point where i want to get some new turbos and obviously i need some new injectors and fuel control to go with it, only question is do i want to try to control timing as well, all things considered i havent even attempted any fuel trimming yet and who knows if im even gonna be able to figure that out
#14 (permalink) | |
Dont f#@k with me I own a
At least this is what happened to me with 1.6n and 1.8g.
#15 (permalink) | |
You could start with some dsm 450's and get the hang of tuning with smaller injectors that need no timing control than move on bigger. DSM injectors are cheap and might even be all you need. Than after your more comfortable tuning move up to some evo 560's which are more than enough for most but will probably need some timing control. |
#16 (permalink) | |
Here for the tuna.
#17 (permalink) | |
Supporting Vendor
I am trying to get this to work also on my HHH. how did you set up your User Defined options.. what is the formula and ID to get that to work?
Jason@PriceMatchedParts.com 3000GT/Stealth Performance parts! www.PriceMatchedParts.com PMP on Facebook!! PMP on Myspace!! PMP on Twitter.com too!! PMP on Digg check out PMP CCOTM! 91 vr4- Budget build! stay tuned! 1 of 3 in the US |
#18 (permalink) | |
I wish I could be more help. Axe |
