Old 07-21-2008, 11:59 AM   #1 (permalink)
Nuclear Nerd
jat2339's Avatar
Drives: 1991 Stealth TT
jat2339 is an unknown quantity at this point
Default AEM UEGO to stock ECU??
where the crap kind i found out which pin to hook the 0-5v wire from my AEM UEGO to the stock ECU, i know there is an extra egrt pin but which one is it?? I have an OBD I btw
Mod. list
Stillen down pipe w/gutted rear pre-cat.
Greddy Profer E-01 on the way.
HKS cosmo fuel pump w/ hotwire.
Matrix open element air filter.
NGK 8MM plug wires
Carbotech slotted rotors.
Maximal Tcase bracket.
more to come....EVO 560's and 15G's and an SAFC-2???
jat2339 is offline   Reply With Quote
Old 07-21-2008, 12:13 PM   #2 (permalink)
3000GTVR41994's Avatar
Drives: 08 Eclipse RIP VR-4
Trader Rating: (12)
3000GTVR41994 Level 13000GTVR41994 Level 1
Default Re: AEM UEGO to stock ECU??
Hey, this should help you out. Stealth 316 - ECM pin assignments
Rob
RIP ^^^
Custom Subwoofer Box For Sale: Sub Box
3000GTVR41994 is online now   Reply With Quote
Old 07-21-2008, 12:13 PM   #3 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (62)
#53
http://www.stealth316.com/images/ecu_91-93_5.gif
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 07-21-2008, 12:20 PM   #4 (permalink)
Trader Rating: (12)
lol, you must be just as bored at work as me
Old 07-21-2008, 12:30 PM   #5 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (62)
Oh hell yeah.
Old 07-22-2008, 10:35 AM   #6 (permalink)
Nuclear Nerd
jat2339's Avatar
So am i splicing into a wire or am i adding a pin to the connector?
Old 07-22-2008, 10:43 AM   #7 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (62)
Afaik, splicing a wire. I think you should already have a pin. I have this on my own to-do list but I haven't actually done it yet.
Old 07-22-2008, 10:50 AM   #8 (permalink)
Trader Rating: (12)
Your correct, you splice in. I currently use the HHH logger and am able to log my WB using this method.
Old 07-23-2008, 04:06 AM   #9 (permalink)
Nuclear Nerd
jat2339's Avatar
well since someone is actually payin attention to this thread, do you guys know anything about the error in IDC when using MMCD on a palm pilot, it sounds like my logger is useless for IDC??
Old 07-23-2008, 04:30 AM   #10 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (62)
You mean how it reports IDC too high? I have no idea, but if you log IPW and RPM you can generate accurate IDC #'s.
