AEM EMS no engine speed reading
I'm not getting an engine speed reading from my ems while cranking, I have changed my CAS and PTU. My fuel pump solenoid and fuel pump resistor is not hooked up (I don't think it would make a difference) on the ems CRANK TOOTH period is remaining unchanged at 130560 and TP2PER seems to change while cranking. I have triple checked my wiring to the ecu harness at the EMS. What should I check?
any help would be appreciated
note: I put the ems in a 1G stealth I have and it fired right up and had an engine speed reading so that eliminates a bad unit
Used stock parts for sale PM for more info.
If you need work done on your 3S I can help, I am located in the Northern Virginia call me at 540-454-0925 - Robert
